1 members (tommog),
223
72
Topics49,849
Posts837,425
Posts: 30 |
I am aware of several 3.7L Roadsters suffering terminal engine damage during enthusiastic track day driving as a result of oil starvation. Apparently on long track corners or a quick left to right or visa versa the sump oil gets forced up one side of the sump housing and leaves the strainer mid-air. The result of which you can guess. Has anyone had a sump modified ( baffled ) or gated thus reducing the oil slop and mitigating the starvation, if so who carried out the work. As you may guess I am one such owner who enjoys one or two-track days each year (COVID allowing) and has now purchased a set of wheels shod with soft compound rubber thus potentially bring the disaster closer. When i last spoke to the factory about this there solution was 'just stick an extra liter of oil in the engine'. not sure I am happy with this as I am told this act can cause hydraulicing and subsequent damage of a different kind. Any advice/experiance welcome. I think this is probably directed at Simon (SIFAB) because if I need a modified sump he is probably my man.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Yes, try Simon. Cain at Wolf performance also does them.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,127 |
Hello dear Paul,
facing the same concerns i went for an ACCUSUMP additional oil feed system... works fine! :-)
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 1,415 |
I’ve been asked a couple of times about this
I’ve got a dummy engine lined up to prototype on, just need some time ....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 30 |
HI Simon. I think quite alot of 3.7l owners would be interested in this. When do you think you can develop a solution. Id be happy to run my car over so you have something to work on if that helps.
