2 members (yobtaf, BHV),
256
40
Topics49,860
Posts837,486
Posts: 119 |
Ok, got around to labeling the photo. Take a look and tell me if this looks right. Two things I'm not quite clear on: - L/R wipers... are you saying that you can select which wiper to turn on with that?
- Generator Indicator... what exactly would that be warning you of?
Posts: 3,696 Likes: 131
Posts: 3,696 Likes: 131 |
I read Phantod's reply as that the switches "from L-R" are Wipers, etc...
Generator indicator = ignition light?
Bottom left according to Edgar is Washers.
Posts: 119 |
I read Phantod's reply as that the switches "from L-R" are Wipers, etc... Ok, that makes more sense. Was doing this late at night so pardon that backwards thinking on my part.  Generator indicator = ignition light?
On the indicator, yeah, I could see what you mean. As for the washers, I'm assuming he meant 'windshield washers / wipers'?
Posts: 119 |
OK, updated the image (it'll show up above updated as well).
Posts: 119 |
Ok, I'll be damned... the car actually has a windshield washer... I was having a hard time grasping what you guys were referring to because I didn't think a car like this would have that kind of option that far back.  It's even in the photo... the hole that the liquid sprays out of is so darn small I didn't even notice it!
Posts: 516 Likes: 1
Posts: 516 Likes: 1 |
Although it seems from your photos that mine may not be original, on my 1966 plus 4 the heater switch is where your choke is and the screen washer is a fourth (spring loaded) toggle switch, so I have two switches either side of the power feed. My choke pull is attached to the steering column on a bracket, so there are no switches fixed directly through the dashboard.
Malcolm T
Malcolm T 1966 +4 1957 TR3 1963 TR4 1983 LR 110 1985 Robin Hood 2.0l
