3 members (JohnHarris, TalkMorgan, Graham, G4FUJ), 327 guests, and 97 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
flaagan Offline OP
Ok, got around to labeling the photo. Take a look and tell me if this looks right.
Two things I'm not quite clear on:
  • L/R wipers... are you saying that you can select which wiper to turn on with that?
  • Generator Indicator... what exactly would that be warning you of?
I read Phantod's reply as that the switches "from L-R" are Wipers, etc...
Generator indicator = ignition light?
Bottom left according to Edgar is Washers.
2011 Morgan 4/4
1932 Austin 7 Chummy
flaagan Offline OP
Ok, that makes more sense. Was doing this late at night so pardon that backwards thinking on my part. doh
On the indicator, yeah, I could see what you mean. As for the washers, I'm assuming he meant 'windshield washers / wipers'?
flaagan Offline OP
OK, updated the image (it'll show up above updated as well).
flaagan Offline OP
Ok, I'll be damned... the car actually has a windshield washer... I was having a hard time grasping what you guys were referring to because I didn't think a car like this would have that kind of option that far back. laugh2 It's even in the photo... the hole that the liquid sprays out of is so darn small I didn't even notice it!
Although it seems from your photos that mine may not be original, on my 1966 plus 4 the heater switch is where your choke is and the screen washer is a fourth (spring loaded) toggle switch, so I have two switches either side of the power feed.
My choke pull is attached to the steering column on a bracket, so there are no switches fixed directly through the dashboard.
Malcolm T
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
