Morgan Aero 8
3 members (stumog, Image, How), 314 guests, and 85 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
GLLHG #65696 01/08/11 12:30 PM
I HATE the gel battery on the S1. Went through 3 in my 3 years of ownership at £140 each time. A conventional battery is a serious improvement on the S2!
Hope your problem gets sorted quickly. Sounds like a starter motor solenoid relay. When my gel batteries died, tyou wouldn't even get the click...
Harry F #65703 01/08/11 03:06 PM
Mr Fezza
Mr Fezza
Also - could just be the 20 Amp starter fuse. Worth checking it. Usually when my S1 didn't start it was this that had blown.
Maxxed out!
mr_tony #65715 01/08/11 08:38 PM
t50 Offline
Hi had the same problem with my mk1 earlier in the year.First check you have the 20amp fuse fitted then try jump leads, if it still clicks you need a new starter motor.I tried all this but the only way it would start was by pushing it. I had a new starter fitted at Millers in High Wycombe and would recommend them highly for there advice a good quick and reasonable priced job. Ring 01494 448158 and talk to Ann
Bill
t50 #65716 01/08/11 08:43 PM
t50 Offline
Hi The fuse issue was to upgrade from a 20 amp
Bill
t50 #65729 02/08/11 06:34 AM
Yes, from a 20amp to a 30amp. Found this out within a week of ownership as the car had blown 3 fuses in that time.
However, when the fuse blew, the starter wasn't even clicking, so I'd doubt that the issue is related to this and sounds more like a starter motor issue or a bad earth as has been suggested beforehand.
t50 Offline
What I was saying if it starts with jump leads the starter motor is o.k. If it still clicks you need a new starter motor.
mr_tony #66521 14/08/11 10:08 PM
Mine started like that (on an S1), I kept blaming the battery, then fuses started blowing. Some say the 15 amp fuse should be 20 amp- but the problem for me that the starter motor was sticking. Ended up fitting a new one and everything else was hunky dorey.
Morgan Aero 8 S5
Porsche Macan S
Honda e
MV Agusta Turismo
KTM 790 Duke
