0 members (), 225 guests, and 78 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 4 of 9 1 2 3 4 5 6 7 8 9
LightSpeed #666265 08/10/20 09:46 PM
The weight gain is 17-1/2 pounds. Soon I get to weigh the Bleazey kit. Kit arrived and weighed a total of 5-1/4 pounds, a savings of 12 pounds.
No more big clunks and the belt changing tension because of BB movement.
LightSpeed #666271 09/10/20 03:17 AM
Phil’s kit is pretty easy to install as well. Great winter project. Enjoy!
2017 M3W Sport Green
2Sharp #666306 09/10/20 11:37 AM
Thanks Ken, but I am going to need something else for winter because this will be done tomorrow. Getting the NVH out looks like the most difficult process and that is now sitting in a corner of the shop.
LightSpeed #666310 09/10/20 12:11 PM
Getting the floor panels* bent down was IMHO the most difficult process wink
* these are bolted and masticked. The mastic is a pain. Note I managed to redo the bolts after fitting the new BB mount.
But indeed you will then likely need another project from November. Maybe rustproofing the inside of the chassis tubes? smile
LightSpeed #666317 09/10/20 12:56 PM
The inside of the frame,,, if all that waxy goop that seems to be everywhere did not find its way inside the frame then how could I get in there? I would hope the frame was dipped to seal it but I suspect it was sprayed since the car was built in an antique shed that was probably a converted dairy barn a hundred plus years ago.
I try to not drive through rivers and creeks or rain storms and so far have succeeded. I sold my drysuit so I don’t go kayaking anymore 😊
LightSpeed #666320 09/10/20 12:57 PM
Hopefully you will post some pictures of the change
Rodger
2004 Plus 8 (wife's)
2Sharp #666402 09/10/20 08:56 PM
I have the parts and am planning the BB upgrade this winter. Has anyone on the East Coast done Phil's Centa upgrade. That is a bit more daunting to me.
2016 M3W
Cuna2016 #666414 09/10/20 10:03 PM
Not sure where New Hope is but I am in Leesburg, VA also Emil from Morgan Customs who is in PA both installed Phil’s kit. Emil has a nice shop so sure he would install it for you. If there is time this year happy to go for a ride and help out. Having a lift makes it a lot easier.
LightSpeed #666420 09/10/20 11:33 PM
Emil will be doing a couple of Centa drives within about a month so I would contact him ASAP if a Centa is in your future. He also has done a few of the BB Mounts and has one on his machine. Give him a call and introduce yourself.
LightSpeed #666425 10/10/20 05:33 AM
O
O
ABT makes (or did make) the chassis for the M3W..
http://www.talkmorgan.com/ubbthread...ple-of-things-to-look-out-for#Post662870
