6 members (RibbleAdventures, Gordon D, Image, xc68anc, AndyrIch, Craig Jezz), 294 guests, and 43 robots.
Adam12 69
+8Rich 67
John V6 61
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,368
Posts813,414
Members9,215
Rbt Aero8, Salmon, stevends
#668894 25/10/20 10:33 AM
On my new-to-me 2017 Plus 4 the speedo is way over to the left, away from an easy glance to check one's speed.
So like others I've read about on TM, I thought I would fit a small discreet digital readout on the top of the steering column.
I acquired one with a nice easy-to-read display that simply plugs into the OBD port - and it worked perfectly in my tin-top (2014 Golf GTD). However, plugged into the Morgan, all the functions work except for the speed!
So am I right in assuming that the OBD on the GDI engine setup is not Euro OBD2? The instructions with the display showed a few different wiring protocols that involved changing/removing some of the pins - which I tried, but none of those options worked any better.
I have acquired another, solderable OBD plug - so I could rewire the lead to suit the Mog, if I only knew how (or even whether it's possible!) - ie which pinouts provide the speed sensing and so on.
Any OBD wiring/pinout experts out there, please?
Many thanks if you can help!
Keith
2017 Plus 4, deep blue
Some useful stuff here from Wicki. As you can see there is plenty of manufacturers discretion on the pinout standards. Buying a Ford friendly OBDII Bluetooth adaptor seems to help therefore and setting up the display app to match of course.
I bough a GPS speedo on flea bay. It connects to the USB port on the radio so comes on with the ignition. About £16.
2025 MG ZS EV aka Trigger
Thanks Richard. I'll look into that. Trying to keep it to a hard wired option rather than Bluetooth.
Keith
I have a unit to plug in to the port with an app on the phone but that doesn’t show the speed either.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Thanks John. I actually tried one of those as well - the numeral font wasn't anywhere near as clear and readable as the OBD one.
Keith
If you use your phone there is also an app called GPS speedo.
I found on both Roadsters that one OBD rader I bought didn't work on fords. I have a cheap blue tooth dongle that works well with the Torque app
Rog Offline
Hi Keith
Not familiar with the GDI but would hazard a guess that the non-Ford MBE ECU doesn’t control the speedo over any of the OBD2 CAN protocols and perhaps the speedo grabs its pulses directly from the sensor on the front wheel hub?
Awaiting to be shot down..... smile
Roger
John, what is the brand of your functioning OBD reader? I have tried the ELM 327 on my Roadster S1, but no luck. Seems to connect in some way, but no readings. What is your solution?
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Robbie it was cheap one of ebay.
Sadly I can't search purchase history far back enough to find it.
Here is a
[Linked Image sorry about the glare from the polished bonnet.</div>
<br>
</div>
<div class=
