4 members (MATTMOG, sewin, DavidR, Robbie), 520 guests, and 39 robots.
+8Rich 70
Adam12 69
John V6 53
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,508
Members9,215
Winglad
Page 3 of 3 1 2 3
Rog Offline
Originally Posted by Tim Crump
I have the Torque app and on my GDI +4 it does not seem to be able to read speed. It cheats and displays the speed according to the GPS from the phone!
The GPS will most likely be more accurate anyway, I use a digital dashtop readout of speed taking data from the OBD2 port and it's around 5 - 8% high
Jon, I assume your car is still very much Ford based? I wonder if a Ford dealer could improve your speedo accuracy? There are many parameters that can be adjusted on the Ford ECU’s using the dealer software including the rolling diameter of the tyres and axle ratio.
Roger
Only thing is...it’s not a Ford ECU....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Rog Offline
Hey Ho...... smile
Roger
It's the 3.7 Roadster, so the speedo is fed off the ECU / BCU combo for its readings, although I assume packaged as Ford (Mustang), access for tweaking is locked - many have tried, even some of the more innovative dealers and none seem to be able to crack it
Hence they can't cure the rev hang either banghead
Originally Posted by John07
The Classic parts book for the 2014 onwards +4 shows a VSS sensor on the chassis page, is this the Vehicle speed sensor?. I assume it comes from one of the front wheels as when I had my car on a RR dyno the other week the speedo did not work. The signal must end up in the ECU at some point as the tickover speed does depend on road speed.
I do find the later wiring diagrams hard to read, or is it just me?
Cheers
Well spotted John and the location on the harness does suggest its connector is at front of car so tying in with your front wheel location assumption (seem to remember DaveW referring to such). Checked cables from it and as far as I can tell they go direct to VDO master gauge connector on dash. Could not find any similarly coded cables going to ECU or BCU suggesting it is a closed circuit to speedo.
Thanks to everyone for all the replies and insight. Just the technical knowledge I was hoping for from the forum, albeit not with the outcome I was hoping for. So I've spotted a better, GPS display (hopefully more easily read than the one I tried already) and ordered that. I'll report back in due course (a few weeks probably) if it works out ok.
Keith
2017 Plus 4, deep blue
Page 3 of 3 1 2 3
