0 members (), 300 guests, and 36 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Page 13 of 14 1 2 11 12 13 14
I am looking for a picture of inside the pipe at the baffle. I am thinking if they are tack welded like Harley exhaust you can just use a rod and hammer and drive the baffle out. I did that on several stock pipes in the past. I don't know how these things are made so I can't say if you can do this with these pipes
Not a great picture, but here is an image of my drilled front baffle:
2016 M3W
The baffles are numerous, 4 baffles in my pipes. 0ne at 24" in from the front and another at 44" in from the front and then two in the back. One about 11" in from the back and another a few inches further in. The rear baffle locations you can see with bumps/rivets on the outside of the pipes. You would have to knock all of themout and good luck with having a pipe that was straight by the time you did that, and then you still could have the cats.
Just buy a good drill bit and some extensions.
That looks like the most forward rear baffle that can be seen in your photo. Good photo btw since it is a long dark hole.
A long flat blade screw driver works well to remove the cats, they are not difficult to remove. The biggest difference to the heat issue and freeing up the engine is the removal of the "solid" baffle and free flowing air filter, the noise increase is also not too dramatic. I think the best advice is to remove that baffle first, drive and then decide if you want to remove the rear baffle, drive again and if you want remove the middle baffle. In my case I removed the front baffle then drove for a season, then decided to remove the rear baffle, great performance lovely noise no heat and cost $60. Yes, use the drill to remove the baffles do not attempt to knock them out.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Thanks for the advice. I am going to go drive the car stock and see what it is like. Then I will do the front baffle first, then the cats if I still have a major heat issue, then if that doesn't work I will buy the G56 pipes.
I had two front baffles and two rear baffles.
Put a small amount of never seize on the pipe connections to make it easier to remove and replace.
Did you remove both of the front or just one?
Your exhaust was probably an exception as there have been no other reports of more than 3 baffles in each pipe.
Hogzilla,
If you are going to drill out the baffles then this guide can help:
http://www.talkmorgan.com/ubbthreads.php/galleries/627053/re-prelim-bafflectomy-procedure
My recommendation is to remove the guide drill bit from the drill head, use lubricant such as cutter fluid or WD40 don't use the hammer drill but start the drill slowly without too much pressure this gets into the stainless steel and then speed up.
Bruce
2013 M3W (Olga)
Hogzilla,
Thanks. I am having trouble getting an extension for my hole saw. I have one for a 1/4" drive and I need a 1/2" drive. So I will have to invent something that will work. I can tell the motor is wanting to breathe. I will help it as soon as I can!
