7 members (BLUE+4, John V6, B3MOG, B&C Morgan, nick w, Strathaven, Deejay),
149
63
Topics49,859
Posts837,498
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
I've seen posts regarding fitting the 4 seater 4 leaf rear springs. My car is a 1974 2 seater. The rear suspension is, to say the least, somewhat firm. I'm wondering if the 4 leaf springs would be of benefit. Or are there different ones for the 2 seater?
I'm just about to lubricate the springs with chain oil to see if that makes a difference.
Posts: 2,583 |
Chain oil really does make a difference - try that first before going to the expense and trouble of a replacement set.
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
I had the 7 leaf on my 4 seater. Changed to the 4 leaf and has transformed the ride quality.
Fitment was not without issues, but very pleased with the result.
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
Oil them first with motorcycle chain grease. It makes an amazing difference if they are dry. Take off the spare wheel so you can get to the rear shackles.
Posts: 8,672 Likes: 411
Posts: 8,672 Likes: 411 |
My Land Rover has aftermarket parabolic leaf springs fitted. These offer so much greater articulation that matching longer travel dampers have to be fitted. The main advantage though is that with just two leaves used there are fewer sliding surfaces between them, allowing better compliance. This also offers better tolerance to infrequent lubrication FWIW.
TBM's findings of an improvement with fewer leaves makes me wonder if there are advantages of using fewer still but stiffer leaves with a Mog.
I fitted parabolics to my S2A - a massive improvement. I was surprised they were not an option for the Morgan.
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
I fitted parabolics to my S2A - a massive improvement. I was surprised they were not an option for the Morgan. SSL (ex Suplex) were developing some
I fitted parabolics to my S2A - a massive improvement. I was surprised they were not an option for the Morgan. SSL (ex Suplex) were developing some I don't think it came to anything. I chatted with Peter a lot when I upgraded and he recommended the standard 4 leafers I bought.
Posts: 318 Likes: 5
So are the 4 leafters valid for a 2 seater as well as the 4 given the lesser load requirement of the 2 seater?
Posts: 22,359 Likes: 353
Posts: 22,359 Likes: 353 |
The four seater springs work well on the two seater. Recommended by Peter Mulberry to me a few years ago.
