1 members (Ian B),
319
104
Topics49,867
Posts837,614
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Oh, today I noticed that the glue of the hood has come off at the front frame. Which glue should I use? One photo is in fast motion when the suction lifts the canvas. The other one with my finger when standing still. I'm afraid that without glue the roof canopy might break at higher speed. Is there something special to take into account? It is a 2014 everflex easy up. ![[Linked Image]](https://www.tm-img.com/images/2020/11/11/1F03534C-AD7A-4B99-A6C2-5ED612FC61E1.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/11/11/179A897C-BB59-4151-9360-80B85C941F2C.jpg)
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
You could try an email to Allon White's & see what Shaun recommends
Posts: 8,680 Likes: 413
Posts: 8,680 Likes: 413 |
I have some leather work booked there next week so will ask Shaun then. I need to re-glue outer edges of hood top rail seal.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Back in the summer the rubber u seal in the header over the windscreen frame started to come away , I used good quality super glue , held down with washing spring pegs for 24 hours.so far it has worked.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
I good solvent based neoprene glue like bostik should work. It needs to be flexible.
Posts: 502 |
Great idea. I had to glue my seal recently, and used some off cuts of wood I had lying around which were a perfect fit. Spring pegs would have allowed a more precise hold.
2004 Series 1 Roadster
Posts: 51 |
Although it is not stuck, the hood will not come loose or come off, as it still glued around the front and under the front rail.
But couldn't it wear out if the wind always tears at the edge, Gary?
