4 members (RichardV6, High Hamster, Martin W, jbk), 221 guests, and 51 robots.
+8Rich 77
Topics49,859
Posts837,513
Jonny72
TimB Offline OP
uhhh - I paid 450+VAT at NewElms... (including the brake pads)
TBM Offline
That's steep! £108 more than the BerryBrook ones. Mine were including stainless brake lines and pads too.
TimB Offline OP
ok - forgot the brake lines. Tim incldued them in the kit as well
Originally Posted by TBM
Originally Posted by SimonH
You have to file a bit of the caliper bracket away to make them fit
You should have been told this or it should have been with the fitting instructions
Thanks for that Simon - I got mine from Mulfab via BerryBrook, and there was no mention in the Mulfab instructions unfortunately.
That's strange, I got mine from Peter and the instructions were clear to file down the bracket. Easy peasy job, I used a Dremel.
TBM Offline
Did you file a 'notch' or the full depth of the bracket?
Wonderful tool thumbs
Every home workshop should have one.
Full depth of the bracket, but IIRC it wasn't that much to remove. It was back in around 2006 that I did it, when I fitted my hardchrome kingpins, so I don't have a clear memory or record of exactly what I did.
TBM Offline
Thanks Tim, will get the dremel out when the pads need changing.
Mulfab isn't Peter anymore though.....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Last year I fitted the Mulfab calipers on my Plus 8. Kept a standard solid disc but added stainless flexi pipes. Two issues...
Getting the seized on solid old discs off! Plenty of Plusgas and patience!
Fitting the new Hispec callipers. The mounting bolt holes were undersize. I phoned Mulfab and they checked their stock.....all with undersized holes. Rather than send mine back for replacement I drilled them out. No further issues. Pads went in fine. Brakes excellent with this upgrade. Very slightly firmer feel due to the hose upgrade.
I just bought the callipers and hoses as I already had new discs.
