7 members (Graham, G4FUJ, teknome, Grumpy2, Bluebricked, mph, Tweed19er, Mogdavid), 303 guests, and 40 robots.
John V6 68
DaveW 64
+8Rich 62
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,069
Captain Morgan, IRWIN
Page 3 of 3 1 2 3
Marmota Offline OP
I really appreciate your comments. It looks like my order is right. As far as I can read, I would do first the Centa upgrade for sure. Then the G56 exhausts. And maybe, if I win the lottery, the Olhins.
The 569 cams doesn't sound like a nice idea if I won't change the ECU. And I won't, as in Spain the MOT checks the emissions, and I don't want to have a bad surprise... with emissions way above the Euro4 specification.
www.speedymarmots.com
The G56 Stage 1 kit is a nuts and bolts job that you can do yourself fairly easily. I think that G56 do a Euro 4 optimised system now, maybe? As the exhaust and filter are easier and quicker to do than the Centa mods, I would put that first and get the benefits now.
And the G56 extra power may quicken the justification/need for the Centa mod too wink
If you are using the power gain for speed and racing, but if you are trying to attain a smooth running engine then maybe not.
I did the Morgan Aero Racing Stage 1 route with S&S Stealth high flow filter and shorter less restricted Morgan Aero exhausts. M3W ran fine but didn’t like the sound of the exhaust. Eventually drilled out the front baffles of the stock exhaust and reinstalled. Works as well and exhaust note much better. Left cats untouched. I do have the upgraded 569 cams and ECU remapped for those cams but feel you really don’t have to do that.
I highly recommend you simply drill out the front baffles of the stock exhaust and not install the G56 or Morgan Aero Racing exhausts and install a S&S high flow air filter with standard ECU. This works just as well as the Morgan Aero Racing and G56 Stage 1, exhaust note is great, and much easier and less expensive. You will be very happy!
There is an earlier thread that explains how to drill out the front baffles. I did it myself.
Best of luck.
Best of luck.
I too might take off the AR Mufflers in favor of the drilled stock mufflers because the AR mufflers are pretty loud. I have already drilled the front baffles but just not installed them yet. I figure it is a good winter project to swap those pipes.
MAGNAFLOW!
http://www.talkmorgan.com/ubbthreads.php/topics/600040/1
Save money ( bunches) superb sound and performance!
High Noon
Just did the bafflectomy. A little louder but much better feel to the engine getting up to speed. Glad I did it.
I had considered Magnaflows since I use them on my truck. If someone would make a bolt on kit here in the US I probably would have gone that route.
2018 S&S 110th Beetleback
1934 MX4 Beetleback
1965 Corvette Coupe 327/350
I am with you on this one. I can weld on farm equipment but nothing thin and nice looking.
A bolt on Magnaflow kit would be great!
Page 3 of 3 1 2 3
