0 members (), 268 guests, and 40 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
Page 15 of 24 1 2 13 14 15 16 17 23 24
#678918 20/12/20 08:45 AM
Boat build
Another experiment in photo posting, this photo was taken yesterday, if this works I will add earlier pictures of the build and bore you all.
Fantastic, it worked, now I can add earlier pictures if there's any appetite for them out in TM land. I might even do it there's not.😂
Gordon Duguid
235 Comments
Gordon D #701637 02/05/21 06:44 PM
Clever idea to hold the belt sander thumbs, I may adopt this instead of bodging it into the old B&D Workmate jaws
Gordon D #701789 03/05/21 04:22 PM
So the result of 12 hours cutting, sanding, routering, jointing and fitting here's the end result ready for gluing in place. Soon as decide about the transom door that is!
Gordon Duguid
Gordon D #703298 14/05/21 03:21 PM
Company work stops early on a Friday so I managed to make a start to caulking the deck.
Bit of a learning curve as usual, secret appears to be removing the masking tape when the sikaflex is half cured.
I also decided that a gate was the best option for the transom opening. Not hinged in the photo but hinges arrived today so maybe this weekend.
Gordon Duguid
Gordon D #703299 14/05/21 03:25 PM
Absolutely beautiful work, credit to you Gordon
Craig Jezz
Gordon D #703499 16/05/21 07:04 AM
Looks fabulous
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Gordon D #706322 09/06/21 06:07 AM
Beautiful woodwork and craftsmanship! Well done!
RenoP53 #706340 09/06/21 09:43 AM
+1
Gordon D #706358 09/06/21 12:58 PM
Very beautiful, remarkable workmanship
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Gordon D #708956 06/07/21 07:19 PM
Thanks again for your comments. Much appreciated.
Progress has been slow over the past 8 weeks or so due to work commitments but most of the caulking is done and I got a couple of coats of Teak protector onto the cabin sides and foredeck hatch tonight. This is a new product to me, I've always used Teak oil in the past. Apparently Teak oil draws the natural oils out of the wood and leads to recoating at an ever decreasing timescale.
Teak protector is a water based product that lasts 4 times longer than oil and doesn't draw out the natural oil and is UV blocking.
Been getting it wrong all these years ooo
You live and learn.
Hopefully will get the decks coated and get her outside this summer 🤞
Gordon Duguid
Gordon D #709028 07/07/21 02:30 PM
Great progress, all that caulking must get a bit tedious
Where the glazing fits into the frames flush, will you fashion some sort of Bolection cover bead ?
