5 members (Morganmike, DaveW, JohnHarris, Robbie, Ian Wegg), 289 guests, and 33 robots.
+8Rich 92
Topics49,837
Posts837,288
Page 2 of 5 1 2 3 4 5
Holding the mirror with your hand when needed
innocent
www.m3w-jungfrau-treffen.com
I never use them I'm always in front.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
You cannot outrun Motorola...
Originally Posted by rcmatt
my center "dash mounted" mirror is great in that I can see what is directly behind me (unless the rack is full), but down the highway the car behind me headlights make little "O's"
Agreed. I bought the center mount and use it most of the time.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
I bought a some Lucas mirrors second link and they are good however I replaced the glass with hagan mirror glass with a wide view and they are awesome. Also got a hagan rear view mirror.
2017 M3W Sport Green
I use the "hand' damper. Does anyone know of a source of convex glass for the standard mirrors. I find field of view is small.
What type of mirrors did you use. I have had a look at their website, are they worth $95 each?
Just lift off the throttle and have a quick look!!!
1928 Superaero Jap 3 wheeler
2013 5 speeder 3 wheeler
I'm sure you do that in your races innocent
Red Leader drive
Originally Posted by Bitsobrits
Jonathan,
I have the second type of side mirror you linked and it does vibrate much less than the original one (and looks so much better IMHO), but still is somewhat 'fuzzy' at certain RPMs. I find they work just fine for visibility to the rear flanks, but not well at all to the direct rear. I then mounted a small center mirror between the flyscreens which works very well with no apparent vibration. Pretty much the only mirror I use in practice, as looking over ones shoulder to check the flanks is easy enough to do in the M3W.
+1 . I would add that some have tried large reinforcing plates to try and reduce the body mounting flex and shortening the long mounting tube by about half, to improve matters. Not sure how successful this has been though. The second type of mirror and a central mirror works well for me. The half tonneau mirror visibility is worth considering if you drive like that a lot, as Rog G mentions. I doubt there is a perfect set up.
