2 members (Vansrv6, Montegue),
294
Posts837,277
Posts: 718 Likes: 11
Posts: 718 Likes: 11 |
Holding the mirror with your hand when needed
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
I never use them I'm always in front.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I never use them I'm always in front. You cannot outrun Motorola...
Posts: 215 Likes: 6
Posts: 215 Likes: 6 |
my center "dash mounted" mirror is great in that I can see what is directly behind me (unless the rack is full), but down the highway the car behind me headlights make little "O's" Agreed. I bought the center mount and use it most of the time.
2018 S&S 110th Beetleback 1934 MX4 Beetleback (in restoration) 1965 Corvette Coupe 327/350
Posts: 365 |
I bought a some Lucas mirrors second link and they are good however I replaced the glass with hagan mirror glass with a wide view and they are awesome. Also got a hagan rear view mirror.
2017 M3W Sport Green
Posts: 1,947 |
I use the "hand' damper. Does anyone know of a source of convex glass for the standard mirrors. I find field of view is small.
Posts: 902 |
What type of mirrors did you use. I have had a look at their website, are they worth $95 each?
Posts: 79 |
Just lift off the throttle and have a quick look!!!
1928 Superaero Jap 3 wheeler 2013 5 speeder 3 wheeler
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Just lift off the throttle and have a quick look!!! I'm sure you do that in your races
Red Leader
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Jonathan, I have the second type of side mirror you linked and it does vibrate much less than the original one (and looks so much better IMHO), but still is somewhat 'fuzzy' at certain RPMs. I find they work just fine for visibility to the rear flanks, but not well at all to the direct rear. I then mounted a small center mirror between the flyscreens which works very well with no apparent vibration. Pretty much the only mirror I use in practice, as looking over ones shoulder to check the flanks is easy enough to do in the M3W. +1 . I would add that some have tried large reinforcing plates to try and reduce the body mounting flex and shortening the long mounting tube by about half, to improve matters. Not sure how successful this has been though. The second type of mirror and a central mirror works well for me. The half tonneau mirror visibility is worth considering if you drive like that a lot, as Rog G mentions. I doubt there is a perfect set up.
