the challenge I am facing in the my restoration of my 1984 car is that the new "replica" loom from Autosparks is everything but an exact replica for a Ford CVH 4/4. So I am in the process of trying to figure out how to use the new loom (which I am quite is based on a 1988/1989 loom) to fit my 1984 car.
I agree with you - after a fuse, the cable should be green. As it is not (and the volt stabiliser needs a white input) - I think I will keep the white cables on the unfused circuit. I am technically not removing a fuse - I will just not add one as the 1984 have white cables going to the volt gauge and tacho.
To create my own wiring diagram I came across a great freeware called
TinyCadWhen I am done with my diagram I will post a copy of it on my blog.
If somebody wants to do the same -
here is a first version of the symbols used in the Morgan wiring diagrams. Just add this file as symbol library to TinyCad and give it a go.
