7 members (JMcL, aerotaff, BobtheTrain, Zach, davewhite, Pipmac, AlyMatt), 270 guests, and 36 robots.
John V6 79
+8Rich 70
DaveW 67
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,923
Members9,203
toitoine
#682688 12/01/21 02:32 PM
Just to ask, I have a Morgan plus 4 2020 and have noticed a leak of yellow fluid on the steering gaiters. Does anybody have ideas have checked around radiator nothing showing.
Thanks
Ian
Morgan Plus 4. 110 Anniversary
Volvo S60. R Design t5 2020 70 reg
Morgan110 #682693 12/01/21 02:55 PM
Yellow is very odd. What colour is the coolant?
Being so far forward then coolant seems the most obvious.
2025 MG ZS EV aka Trigger
Morgan110 #682696 12/01/21 03:18 PM
A yellowy green could be coolant, but could also be clean oil?
Can you post pictures?
Morgan110 #682698 12/01/21 03:38 PM
Others wil throw their arms up in horror, up to you if you want to try this (it’s how most mechanics check). Touch your finger in the liquid and touch to tip of your tongue for a second. Anti freeze is sweet.
Oil (sounds daft) can’t be mistaken is it’s clearly oily.
Not much danger of it being battery overflow these days or I wouldn’t have mentioned it, plus your a long way away from your battery vent and your year of car doesn’t have one.
BR
Colin (I repeat, your call if you try this or not ;-))
BR Colin
Morgan110 #682712 12/01/21 05:17 PM
Ray Offline
Is it power steering fluid?
Morgan110 #682714 12/01/21 05:18 PM
And just hope it isn't brake fluid. But Colin in reality that is what i would do, with a pint of water to rinse the mouth.
Of course it could be a small dog sneaking into the garage AKA don't eat yellow snow.
Ray #682716 12/01/21 05:19 PM
We have electric power steering. No fluid has been hurt in turning the wheel just electrons. laugh2
Morgan110 #682717 12/01/21 05:22 PM
It could be a number of things:-
Coolant- although the factory tend to use red antifreeze
The lubricant (semi fluid grease) used in the steering rack- It can leach past the rack gaiters
The under seal the factory apply liberally over everything, its a yellow/gold colour....if it has been sprayed on the radiator it will melt when its hot and drip....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Morgan110 #682718 12/01/21 05:25 PM
My first thought was liquid grease from the steering rack. If its thick and oily to the fingers that will be it. It will be coming from a split or leaking gaiter (had both these faults on mine, both fixed under warranty) and settles on the centre under part of rack.
If one of the gaiters are split suggest getting hold of these and asking your dealer to replace with same under warranty. If he agrees ask for the MMC replacements he won't have used. Inferior but handy as a spares.
Morgan110 #682735 12/01/21 06:56 PM
They all do that Sir ! read
