Topics49,859
Posts837,513
Posts: 15 |
Should there be an OBD / diagnostic port of any description hidden away on my 4/4 (1994, 1.8 zetec)?
If the answer is 'yes', what should I be looking for? So far, I've failed to find anything hidden away behind the dashboard which looks even remotely like the OBD port I'm used to.
Iain 1994 4/4
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
If I remember correctly Ford had a 3-pin version of diagnostic connection. I had a 1993 4/4 with a cvh efi engine that had that 3pin port that preceded the OBD standardisation to the multi pin port. I did manage to find a Draper diagnostic tool for it but never needed to use it and sold it. Try the Ford owner forums as another option.
Posts: 5,587 |
Very near the ecu ?
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
If it's in the same place as on my '93 silvertop Zetec it's under the bonnet on the bulkhead drivers side. I'll have a look in a bit and get a photo if necessary.
Three photos. Two show the OBD ports - red caps. One shows the OBD reader - 2 connectors to the OBD ports and one to 12V live. I think the reader was a Draper part, but a Google search for 1994 Ford Mondeo (other models are applicable) diagnostic code reader should find one. ![[Linked Image]](https://www.tm-img.com/images/2021/03/12/OBD-port_1.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/03/12/OBD-port_2.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/03/12/OBD-reader.jpg) Hope that helps!
Posts: 15 |
If it's in the same place as on my '93 silvertop Zetec it's under the bonnet on the bulkhead drivers side. I'll have a look in a bit and get a photo if necessary. Thanks for the reply and photos, found them exactly where you said they would be.🙂
Iain 1994 4/4
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
Excuse the slight drift of thread but does anyone know exactly where the diagnostic port is on a 2002 4/4? There are sheets of rubber under the dash which hinders a quick peep.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I think by law the OBD socket has to be within 200mm of the steering column, on newer cars anyway . My '95 has it on the passenger side but would be within 200mm if the car was LHD.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Thinking back to my 1993 car Graham’s photos ring a bell. The port was under the bonnet on the rear part of the engine.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Excuse the slight drift of thread but does anyone know exactly where the diagnostic port is on a 2002 4/4? There are sheets of rubber under the dash which hinders a quick peep.  Under the dash inboard of the glove compartment on my 2002 4/4
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
