3 members (MartinB60, JohnHarris, Ncik P), 314 guests, and 40 robots.
+8Rich 83
Topics49,860
Posts837,495
Jonny72
#692981 11/03/21 04:45 PM
JNI Offline OP
Should there be an  OBD / diagnostic port of any description hidden away on my 4/4 (1994, 1.8 zetec)?
If the answer is 'yes', what should I be looking for? So far, I've failed to find anything hidden away behind the dashboard which looks even remotely like the OBD port I'm used to.
Iain
1994 4/4
JNI #692990 11/03/21 05:24 PM
If I remember correctly Ford had a 3-pin version of diagnostic connection. I had a 1993 4/4 with a cvh efi engine that had that 3pin port that preceded the OBD standardisation to the multi pin port. I did manage to find a Draper diagnostic tool for it but never needed to use it and sold it. Try the Ford owner forums as another option.
JNI #693014 11/03/21 06:55 PM
Very near the ecu ?
JNI #693066 12/03/21 07:21 AM
If it's in the same place as on my '93 silvertop Zetec it's under the bonnet on the bulkhead drivers side.
I'll have a look in a bit and get a photo if necessary.
JNI #693082 12/03/21 09:04 AM
Three photos. Two show the OBD ports - red caps.
One shows the OBD reader - 2 connectors to the OBD ports and one to 12V live. I think the reader was a Draper part, but a Google search for 1994 Ford Mondeo (other models are applicable) diagnostic code reader should find one.
Hope that helps! smile
JNI Offline OP
Thanks for the reply and photos, found them exactly where you said they would be.🙂
Iain
1994 4/4
JNI #693378 13/03/21 06:01 PM
Excuse the slight drift of thread but does anyone know exactly where the diagnostic port is on a 2002 4/4? There are sheets of rubber under the dash which hinders a quick peep. thinking
1994 +8, BMW Calypso Red.
How do you open the boot?
JNI #693430 13/03/21 09:38 PM
I think by law the OBD socket has to be within 200mm of the steering column, on newer cars anyway . My '95 has it on the passenger side but would be within 200mm if the car was LHD.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
JNI #693482 14/03/21 10:44 AM
Thinking back to my 1993 car Graham’s photos ring a bell. The port was under the bonnet on the rear part of the engine.
Under the dash inboard of the glove compartment on my 2002 4/4
Simon
2002 4/4
2021 Audi A1 sport
