Posts837,274
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
They seem a bit small - I'd be more inclined to fit something like this Powerflex Bumpstops
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
TBM - I fitted Rog’s Bump stops to my Plus4 and they transformed the car - rather than puny add on ones as per Deemon Tweeks, I would strongly recommend Rog’s fittings - a) they are substantial and well engineered and b) the height is adjustable as we know no 2 Mogs are alike so effect is achievable no matter the car. I now have a plus four - brilliant car - but for those with a steel chassis I think Rog’s bump stops are a really worthwhile addition
Usual disclaimers- just a happy customer!
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Usual disclaimers- just a happy customer! +1. Totally transformed my 4/4. A most brilliant design and quality fitting. Nick
Not disputing the effectiveness of them, just wondering if anyone has fitted the damper rod bumpstops and done a comparison?
I have Armstrongs (with adjustable valves) and no rear tube, so not something I can do on mine. I have made some axle bumpstops which do a similar job to Rog's.
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Thanks chaps  Re the Powerflex TBM there’s another consideration too I think. There is next to no if any spare movement in some of the dampers in both compression and extension (I know I had a pair with not enough movement). Those PU Powerflex stops are very stiff indeed, installing those potentially transfers some significant bump loads to the damper mounts. Specifying and sizing something with the suitable compliance might be tricky in the available space and as Robbie says all cars are different, even from side to side. The rear damper attachment points particularly on the earlier cars are not so robust. ![[Linked Image]](https://dl.dropboxusercontent.com/s/081lfxe9tyexg60/broken.jpg)
Roger 2011 Plus 4
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Agreed Rog. I think if you did do that to the shocks you should ensure you have the later hanger design but you could be over stressing the hangers. Mine broke on my S1 Roadster under load & I replaced both sides. Your bump stops then helped as well. Old hanger ![[Linked Image]](https://www.tm-img.com/images/2019/08/16/IMG-20180616-WA0004.jpg) New hanger ![[Linked Image]](https://www.tm-img.com/images/2019/09/11/20190911_115700.jpg)
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Tim Eyres sells some alternative brake backplate mountings, which had I known about at the time I would have used instead of the MMC uprated items. See here........bottom left image. https://www.newelms.com/rutherford-parts/
I recently got a pair of Tim’s “Rutherfords + 20’s” to try. With the pair that came with the car, the driver side was topping out before full axle extension so the attachments were taking the impact. Old and new ![[Linked Image]](https://dl.dropboxusercontent.com/s/5ubnj7hmgowep60/plus20s.jpg)
Roger 2011 Plus 4
I don't suppose anyone has had a go at fitting Rogers bump stops to an ARP4, with coilovers instead of leaf springs, have they? When loaded my springs do bottom out, with quite a bang too. The alternative is harder rear springs, but that will harshen the ride too or get some longer springs and wind up the clearance a bit. Unfortunately these bumps stops need a damper hoop to attach to and I’m fairly certain the 5 link cars don’t have them.
Roger 2011 Plus 4
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I don't suppose anyone has had a go at fitting Rogers bump stops to an ARP4, with coilovers instead of leaf springs, have they? When loaded my springs do bottom out, with quite a bang too. The alternative is harder rear springs, but that will harshen the ride too or get some longer springs and wind up the clearance a bit. Unfortunately these bumps stops need a damper hoop to attach to and I’m fairly certain the 5 link cars don’t have them. PaulJ, I have a 5 link Roadster and have swopped the OE coilovers for some designed by SSL (Suplex) you get 2 springs of different rates, adjustable spring preload & adjustable shocks, worth speaking to them
