6 members (JohnHarris, DaveW, Robbie, Ian Wegg, MartO, Pittsartist), 285 guests, and 30 robots.
+8Rich 92
Topics49,837
Posts837,288
Page 4 of 11 1 2 3 4 5 6 10 11
TBM Offline
They seem a bit small - I'd be more inclined to fit something like this Powerflex Bumpstops
TBM - I fitted Rog’s Bump stops to my Plus4 and they transformed the car - rather than puny add on ones as per Deemon Tweeks, I would strongly recommend Rog’s fittings - a) they are substantial and well engineered and b) the height is adjustable as we know no 2 Mogs are alike so effect is achievable no matter the car.
I now have a plus four - brilliant car - but for those with a steel chassis I think Rog’s bump stops are a really worthwhile addition
Usual disclaimers- just a happy customer!
Robbie
2021 Plus Four -- Helga
211-WX-1433
+1. Totally transformed my 4/4. A most brilliant design and quality fitting.
Nick
TBM Offline
Not disputing the effectiveness of them, just wondering if anyone has fitted the damper rod bumpstops and done a comparison?
I have Armstrongs (with adjustable valves) and no rear tube, so not something I can do on mine. I have made some axle bumpstops which do a similar job to Rog's.
Rog Offline
Thanks chaps thumbs
Re the Powerflex
TBM there’s another consideration too I think. There is next to no if any spare movement in some of the dampers in both compression and extension (I know I had a pair with not enough movement). Those PU Powerflex stops are very stiff indeed, installing those potentially transfers some significant bump loads to the damper mounts. Specifying and sizing something with the suitable compliance might be tricky in the available space and as Robbie says all cars are different, even from side to side. The rear damper attachment points particularly on the earlier cars are not so robust.
Roger
Agreed Rog. I think if you did do that to the shocks you should ensure you have the later hanger design but you could be over stressing the hangers. Mine broke on my S1 Roadster under load & I replaced both sides. Your bump stops then helped as well.
Old hanger
New hanger
DaveW Online Content OP
OP Online Content
Tim Eyres sells some alternative brake backplate mountings, which had I known about at the time I would have used instead of the MMC uprated items.
See here........bottom left image.
https://www.newelms.com/rutherford-parts/
Rog Offline
I recently got a pair of Tim’s “Rutherfords + 20’s” to try. With the pair that came with the car, the driver side was topping out before full axle extension so the attachments were taking the impact.
Old and new
Roger
Rog Offline
Originally Posted by PaulJ
I don't suppose anyone has had a go at fitting Rogers bump stops to an ARP4, with coilovers instead of leaf springs, have they? When loaded my springs do bottom out, with quite a bang too. The alternative is harder rear springs, but that will harshen the ride too or get some longer springs and wind up the clearance a bit.
Unfortunately these bumps stops need a damper hoop to attach to and I’m fairly certain the 5 link cars don’t have them.
Roger
PaulJ, I have a 5 link Roadster and have swopped the OE coilovers for some designed by SSL (Suplex) you get 2 springs of different rates, adjustable spring preload & adjustable shocks, worth speaking to them
