Topics49,901
Posts838,045
Posts: 72 |
I buy have just discovered that my handbrake has been binding on the offside so much so that I will need to replace the shoes. I have slackened off the adjuster in the rear as much as I can but there is still some resistance in the drum, however this will of course effect the other drum as the adjuster effects both sides. I didn't notice any binding the last time I removed the rear wheels but that would have been back in September.
Any advice most welcome
Chris 2006 4/4
2006 4/4 70th Anniversary Edition 2004 3.2 Audi TT Quattro
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Are you sure it's a handbrake problem and not a sticky slave cylinder?
Bob
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Are you sure it's a handbrake problem and not a sticky slave cylinder? +1 Most likely.
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
The above suggestions sound far more likely than adjustment, I had the same symptoms on my Plus 8 and changed both rear wheel cylinders and shoes at the same time, end of problem combined with regular fluid changes. Good explanation on gomog.The cylinder change is easy but take a photo of the brake shoes before you strip them and they are a bit of a wrestle to get back on but a DIY job. Good luck.
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Slave cylinder seems to be a common fault. I’ve sorted mine several times on two different cars
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Regular fluid changes help out a bit, every two years seems to work with a bit of rubber grease behind the rear cylinder boots doesn't go amiss either.
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
When changing slave cylinders, keep the old ones and send them off to have them bored out and a stainless internal sleeve fitted.
Posts: 990 |
Great idea Graham - the sleeved cylinders are better than new as they shouldn't go rusty. Is it "pastparts" that offer this service? Can't remember - had a few old Allegro clutch slave cylinders done some years ago.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 8,698 Likes: 498
Posts: 8,698 Likes: 498 |
I've used Past Parts, great service, did a super job on a rare servo made from unobtainium, it came back with a test cert that it now held good at 46 Bar, that's over 600 psi, well pleased
