6 members (Matt C, S2K03, Image, Morganmike, MJF, linklaw), 260 guests, and 42 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,322
Members9,215
#697205 04/04/21 03:33 PM
I buy have just discovered that my handbrake has been binding on the offside so much so that I will need to replace the shoes. I have slackened off the adjuster in the rear as much as I can but there is still some resistance in the drum, however this will of course effect the other drum as the adjuster effects both sides. I didn't notice any binding the last time I removed the rear wheels but that would have been back in September.
Any advice most welcome
Chris
2006 4/4
2006 4/4 70th Anniversary Edition
2004 3.2 Audi TT Quattro
Are you sure it's a handbrake problem and not a sticky slave cylinder?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
+1
Most likely.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
The above suggestions sound far more likely than adjustment, I had the same symptoms on my Plus 8 and changed both rear wheel cylinders and shoes at the same time, end of problem combined with regular fluid changes. Good explanation on gomog.
The cylinder change is easy but take a photo of the brake shoes before you strip them and they are a bit of a wrestle to get back on but a DIY job.
Good luck.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
Yep the slave cylinder
2025 MG ZS EV aka Trigger
Slave cylinder seems to be a common fault. I’ve sorted mine several times on two different cars
Simon
2002 4/4
2021 Audi A1 sport
Regular fluid changes help out a bit, every two years seems to work with a bit of rubber grease behind the rear cylinder boots doesn't go amiss either.
2009 4/4 Henrietta
When changing slave cylinders, keep the old ones and send them off to have them bored out and a stainless internal sleeve fitted.
'09 Gen2 MINI Cooper ragtop
Great idea Graham - the sleeved cylinders are better than new as they shouldn't go rusty. Is it "pastparts" that offer this service? Can't remember - had a few old Allegro clutch slave cylinders done some years ago.
I've used Past Parts, great service, did a super job on a rare servo made from unobtainium, it came back with a test cert that it now held good at 46 Bar, that's over 600 psi, well pleased thumbs
