8 members (Image, Alan Patterson, Sir Percival, ScotiaSteve, sewin, BLUE+4, Pittsartist, Jens),
212
61
Topics49,863
Posts837,561
Posts: 1,947 |
I was discussing parking on a hill & leaving it on gear with handbrake on. Reading the Highway Code it advises if facing uphill turn the wheels to the right ( if on LH side of the road ) & in first gear. If facing down hill turn the wheels to left & put it in reverse. This does not seem right to me, if the car did move it would be trying to turn the engine backwards. I have been in the habit of leaving it in gear opposite to the code advice. Can anyone explain the code reasoning regarding gear selection?
Posts: 5,587 Likes: 603
Posts: 5,587 Likes: 603 |
If the ignition were accidentally left on no chance of it firing and running off ??? .... seems a bit random. Logically reverse would be the best option as it tends to be the lowest gear in the box .... so would be trying to turn the engine over fastest giving most 'engine braking' .... just carry a brick 🙂
Posts: 11,529 Likes: 315
Posts: 11,529 Likes: 315 |
I thought the intention was
1. Steer the ca into the kerb. 2. Do not run the engine in a direction of a bump start (so if facing down then reverse)
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
1. Steer the ca into the kerb. 2. Do not run the engine in a direction of a bump start (so if facing down then reverse) Bang on!
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Get your man to park it for you.
Bet you none of the "AI" in the modern self-parking cars has a clue about that in it's software setup!
Posts: 1,947 |
I get the steering the car into the kerb bit but maybe the first or reverse gear choice is not so important as Saabs used to require the car to be in reverse before you could get the key out.
Posts: 28,900 Likes: 352
Posts: 28,900 Likes: 352 |
I get the steering the car into the kerb bit but maybe the first or reverse gear choice is not so important as Saabs used to require the car to be in reverse before you could get the key out. Used to, but that went some years back (not with either my '55 nor '06 plate 9-3).
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Three safety measures are better than less! I remember a handbrake cable failing but managed to park on a slope using the kerb and gearbox to hold the car. Timing the steering with a hill start was ok. I always leave the car in gear as well as hand-braked as a double check. At home in the garage I leave both free on the Mog as it is level and prevents brake seizing.
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
I remember a handbrake cable failing Yep, I was waiting at temporary traffic lights at the top of a hill a few weeks ago - car started to creep backwards on the handbrale, so gave it an extra tug - big twang and lost it all completely. Almost lost the clutch too by the time the lights turned green......
