10 members (hugo, jbk, GerardNL, nick w, John V6, Jon G4LJW, Hamwich, brownbaker, MJF, High Hamster), 559 guests, and 44 robots.
Adam12 70
+8Rich 69
John V6 52
9,215 Registered Users
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,376
Posts813,553
Members9,215
Hi there I need a fuel pump for the fiat engines plus 4 can anyone recommend a model suitable for the fuel injected fiat engine please
If there are no expert responses on here it might be worth checking with some of the classic Alfa workshops as the later Spiders used a similar injected twin cam.
Alfas use an entirely different engine......
Try: EFI fuel pump
Simon @ Sifab
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Bosch L Jetronic I don't know if this will be of any help because it does list some of the spec.of the fuel pump used
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
Simon - While the Fiat Argenta (which IIRC was the source of the Fiat 2 litre engine for the +4) and Alfa Spider may have had different engines, post 1982 Spiders and the Fiat Argenta both used Bosch L Jetronic injection, hence my suggestion. Autodoc+ lists the same part number (458F0004) for both the Fiat and the Alfa. However I should point out that I am merely an enthuisiast, not an expert!
Hi. One of my Cranmog friends has an Alfa engined plus 4. If you still need help let me know and I will call him.
1980 +8 Blue
And a few others
Stephen
Nigel,
Is this for the 1.6 or 2.0 litre engine? I have a 2.0 which I bought new from the factory and kept in the UK for about 26 years. It was in storage and only used during home leaves from HK. Last time I took it out of storage before shipping it to the U.S. the inside of the tank had completely rusted out. Since mine(1986 fuel injection model) did not have a filter before or after the pump I went thru multiple pumps as each filled up with rust particles.
Don't know if the 1.6 has the same pump but following is what I replaced it with: Bosch Part # R18366A which was 54 pounds Sept. 2011. I added a Mann Filter WK 618 between the tank and pump. Bought six of them and changed after each time I drove it. Cheaper to throw away filters than pumps, but still went thru three pumps trying to keep it running long enough to make it to 60th Anniversary of +4 at Prescott. Also, M. Rutter drained the tank--ouch!
Petrol in Arizona was $ 1.30 cents a gallon U.S. gallon) or under a pound at that time for high test.
All these pumps and filters were bought from GSF Car Parts in Chadwell Heath, Essex. They say they have branches nationwide and their web is: www.gsfcarparts.com
After Prescott I shipped it to Arizona, bought new alloy tank, re-plumbed everything from tank forward and swapped out the fuel injection from Bosch/Magnetti to 1/2 of a Ford Mustang Mega Squirt with modern ECU.
Nothing wrong with the old system but hard to get parts here.
Swapping out the fuel pump is easy--I did it in the driveway of my sister-in-laws home multiple times. If you don't have a filter before the pump, plumb one in. Use filter with 12mm inlet and outlet.
Good luck.
Tom S
Nigel,
Just remembered that WIX make filter Part # 33299 with same fittings which is about 40% the cost of the Bosch unit if available in the U.K.
TomS
Sorry--that should have read Mann and not Bosch for the filter.
Thanks Tom
It’s the 2.0 and thanks for the advice
Great thanks
