1 members (JMcL), 132 guests, and 61 robots.
+8Rich 94
Posts837,276
#700935 27/04/21 05:28 PM
PaulyG Offline OP
Is GoMog still being maintained? I looked up crinkle/wrinkle paint, but it brings me to a different page. Didn't know if I can still contact someone about it.
Or if anyone here knows the technique.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #700936 27/04/21 05:32 PM
when you do a search, there are a couple of check boxes, one for searching gomog only and one for the www. Think you may have searched www as I think that is the default.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
PaulyG #700937 27/04/21 05:34 PM
I'm pretty sure it is you can reach Lorne via PM on here he is would you believe gomog - if that doesn't work I have his personal email if you need it.
Is this the link Paul.
PaulyG #701016 28/04/21 12:20 PM
I’ve just revisited crinkle wrinkle painting with a job on my 1952 +4.
The secret is make sure the aerosol is both warm and well shaken. Likewise the item being painted needs to be at least at room temp.
I then put the (in my case dash panel) item in a hot oven (while the wife was out) for 15 mins to help the ‘wrinkling’.
Getting the paint is easy online however only in black or red. To get ‘early dash brown’ a fine coat of normal brown aerosol over the finished black wrinkle will suffice !
PaulyG #701047 28/04/21 04:11 PM
PaulyG Offline OP
Thanks for the link, Rich.
Bill. Put it in the oven...in the house. Oh boy, that will be an interesting conversation.
73 4/4 "Henry A"
60 MGA
PaulyG #701379 01/05/21 12:51 AM
PaulyG Offline OP
I followed the directions on GoMog. 3 coats of paint, then let it sit for 20 minutes. Nothing happened. I thought I had another failure.
Then into the oven for 20 minutes, and .....WOW!
Now I want to crinkle paint everything!
73 4/4 "Henry A"
60 MGA
PaulyG #701396 01/05/21 07:18 AM
Good job Pauly G. thumbs I remember the first time I used it many years ago, I too expected failure, the oven makes the difference...as long as you don`t get caught doing it .. smile
I wanted to use Sperex yellow on the exhaust but try as I might there was no way of getting them in the oven laugh2
PaulyG #701412 01/05/21 09:07 AM
As Harry Callaghan said....
Do you feel lucky?
The dishwasher cleans parts up nicely too. innocent
Go on, I dare you!
PaulyG #701415 01/05/21 09:14 AM
HJP Offline
As Luddite says Pauly G that's a great job .
Good timing for me as i recently found a rather nice old metal box with a crinkle finish in a skip ! Ive been wondering how to redo it . Sadly too big for the oven , think i might try using a hot air gun on it .
Hugh
PaulyG #701416 01/05/21 09:27 AM
That's really nice Paul, glad it worked out well.
