SORN
New
Topics48,367
Posts813,406
Members9,215
Posts: 60 |
Hi out there, unfortunatly I lost this tiny screws which fix the USB Cover of the ECU. Seems not metric, I tried M3 (to big) and M2 (to small) ... does anyone know the correct size ? Thorsten ![[Linked Image]](https://aufaxe.de/wp-content/uploads/2021/04/USB-ECU-ohneCover.jpeg)
Posts: 2,776 Likes: 59
Posts: 2,776 Likes: 59 |
Hi Thorsten I'm fairly sure that they are UNC 4-40 3/16" long. if you replace the original button head screws with socket cap head screws they are a little bit easier to handle. Some strategically placed duct tape, sticky side up, helps catch the screws when you drop them... or just use duct tape to hold the cover on! The socket head screws take a 3/32" Allen key.
Posts: 60 |
Hi Calum, Thanks a lot, just ordered a set of 10 ;-) Think handling is not the problem. I always use a small piece of old flexible sealant (Dekalin) to 'glue' the screws to the tool ;-)
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
Just to confirm that they are 4-40 UNC screws.
