7 members (Sir Percival, MartO, Mark+4, BLUE+4, JohnHarris, DickJ, Luddite),
149
Old Book
Topics49,940
Posts838,609
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Based upon the exhaust pipe coloration, I now have the left hand cylinder running much hotter than the right. Has anyone else experienced this? Cause?
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
It would be good to use an infrared gun or temperature probe to verify and quantify the temperature difference before getting too worried.
Steve Late 2012 M3W
Posts: 2,098 Likes: 75
Posts: 2,098 Likes: 75 |
Typical of running too a lean mixture. Remove spark plugs and compare colours. Lean will be showing whitish deposits. If confirmed, could be faulty injectors? BUT, I know nothing really about M3Ws in particular.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I found the the Right Hand Cylinder (the rear cylinder) always runs hotter. Possibly something to do with the motorcycle original configuration of the motor wanting the rear cylinder to run more rich because it is in the heat shadow of the front cylinder?
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
Does anyone make a conversion kit to mount the X-Wedge engine sideways on the M3W to compensate for the originally intended configuration?
Craig - Texas, USA 2026 Plus Four 2021 M3W
Thats what MMC does, in theory.
Posts: 423 Likes: 2
Looks to be about 100 degrees F hotter. On the left cyl
Looks to be about 100 degrees F hotter. On the left cyl How and where did you measure it? ProTune readings?
Posts: 423 Likes: 2
Measured at the exhaust pipe before the muffler. Noticed that one pipe was getting very discolored after a short ride the other was staying shiny.
Mine did that too. My rear cylinder (left side facing motor) has always run cooler.
