9 members (GrumpyPa, LeeM, meabh, Mog on Island, xc68anc, Lordofthewings, Image, Graham, G4FUJ, RedThree), 295 guests, and 33 robots.
John V6 65
DaveW 63
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,103
Members9,212
aeroed, DJC, James Mc, JimWhin
Page 1 of 4 1 2 3 4
Lance Offline OP
Based upon the exhaust pipe coloration, I now have the left hand cylinder running much hotter than the right. Has anyone else experienced this? Cause?
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
It would be good to use an infrared gun or temperature probe to verify and quantify the temperature difference before getting too worried.
Late 2012 M3W
Typical of running too a lean mixture. Remove spark plugs and compare colours. Lean will be showing whitish deposits. If confirmed, could be faulty injectors? BUT, I know nothing really about M3Ws in particular.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I found the the Right Hand Cylinder (the rear cylinder) always runs hotter. Possibly something to do with the motorcycle original configuration of the motor wanting the rear cylinder to run more rich because it is in the heat shadow of the front cylinder?
Does anyone make a conversion kit to mount the X-Wedge engine sideways on the M3W to compensate for the originally intended configuration? smile
Craig - Texas, USA
2021 M3W
Thats what MMC does, in theory.
Lance Offline OP
Looks to be about 100 degrees F hotter. On the left cyl
Lance
1981 Plus 8
2016 Three Wheeler
How and where did you measure it? ProTune readings?
Lance Offline OP
Measured at the exhaust pipe before the muffler. Noticed that one pipe was getting very discolored after a short ride the other was staying shiny.
Lance
1981 Plus 8
2016 Three Wheeler
Mine did that too. My rear cylinder (left side facing motor) has always run cooler.
Page 1 of 4 1 2 3 4
