Topics49,871
Posts837,678
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
Coming home yesterday I closed my side screen and the bit sticking out (knob) fell off leaving a rectangular hole in the side screen. I have the piece which fell out which fits neatly in the hole.
Could anyone recommend an adhesive which will fix it back in place without making too much of a mess of marking the Perspex?
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
I did mine with superglue. Worked a treat.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
I've used clear two part epoxy glue on perspex Gary. It dries to similar colour but be careful not to smear it on other than mating surfaces.
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Super glue Gary but with great care to avoid any on the surfaces you look through. By the way it is a feature, they all fall out.
Posts: 697 Likes: 7
Posts: 2,583 |
It`s the new air conditioned sidescreen!. I superglued mine a few years ago and it is still there - I used Locktite gel superglue - easier to control.
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Never had one fall out, but then I hardly use sidescreens.  needed here today
Posts: 681 |
Like Graham, I rarely used side-screens (past tense because I don't have the car anymore) but when the window-opening lug fell off once I used this here . Transparent and very strong. Never fell off again.
Posts: 697 Likes: 7
Many thanks for the comments. I have put it back with Superglue. I’ll report back in a few days if it holds or not.
Posts: 681 |
A minor, but useful, tip - when you want to slide the side-screen open use the lug to bring it back just enough to get your fingers through the leading edge then simply pull the side-screen back. To close, don't use the lug at all but push the window back using the rear edge. Both of these are left-handed operations.
