6 members (Jo S, PeterVD, RichardV6, BobtheTrain, Michael H, John Winn), 237 guests, and 29 robots.
John V6 69
DaveW 68
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,023
RedThree
Rev 4K #705822 05/06/21 07:41 AM
Online NoMood
Have to say I'm horrified when I see those one metre plus breaker bars in use to tighten spinners. The torque they allow such to be tightened to is scary in the wrong hands. Having said that you may need one to undo spinners over tightened by same, fighting fire with fire!
I admit to owning a 600mm breaker bar but use and carry with me one of those pressed steel spinner tools, little over 400mm in length. A few heaves on that tightens and removes to what I regard as sensible torque.
Rev 4K #705829 05/06/21 09:49 AM
This is the best stuff for splines and spinners: [Linked Image]
2005 Roadster 3.0 S1
1960 MGA Roadster
Regards Aage
Rev 4K #705831 05/06/21 10:05 AM
Black Rat
Black Rat
I always use hand tight plus a quarter turn.
Keith
2013 narrow bodied + 4 Ruby.
HJF Offline
Just checked my Britool breaker bar. 58cm knuckle to very the end, 50cm ‘ish to where I would apply pressure. I am fairly lightweight so I feel this is okay. Watched the garage hammer my rears on then a few days later removed them for cleaning using the breaker. Expected a fight but they came off almost too easily! The front ones I had earlier tightened with the bar came off with a similar level of grunt as those the garage had hammered on. So I think I am happy enough with the breaker
Would be someone near Cambridge? laugh2 laugh2 hide I agree Richard you don't need much to get them tight.
2025 MG ZS EV aka Trigger
Rev 4K #705934 06/06/21 08:08 AM
Despite only lightly tightening (40lbs ish) I have to use a scaffolding pole extension to breaker bar & some heat to undo the centre nut. They self tighten over about 3 months. In my case removing the wheel roadside would be impossible.
Rev 4K #705943 06/06/21 09:03 AM
There's a difference between stainless and powder coated wires.
The powder coat grabs the nut. When I had black wires I had the same problem, that only heat and a lot of force would undo the nuts.
With stainless wires that has never happened.
HJF #705946 06/06/21 09:41 AM
HJF Offline
I should have said that what I have described, above, is with stainless wheels.
Rev 4K #705981 06/06/21 01:38 PM
Rev 4K Offline OP
thanks gents,
on the next rainy day the wheels will be off.
2004 Silver Roadster S1
Rev 4K #705985 06/06/21 02:07 PM
Today I took off the passenger side front which for some reason is always the tightest. After less that 3 months it needed the full extension bar.
I used to use the hammer method but on the road side it will need a lot of repeated umph.
