Topics48,352
Posts813,172
Members9,212
Posts: 212 |
So my indicator switch coming out of the steering shroud cover is loose or sqidgy. Feels like there is all kinds of give and doesn't quite move up and down evenly. feels less like it's connected to something and more like it's sticking in a jar of peanut butter. so far it works, but is this something that eventually goes? easy to fix?
end user
Posts: 1,670 |
Sounds like it’s broken - mine did the same on the way down to Switzerland a few years ago LHD or RHD switches can be used it’s just the wires need changing over if the wrong one for your car is fitted.
Posts: 212 |
Okay see now the turn signal stalk breaking and shorting is a big problem. I will look into buying the replacement part and hope it's a DIY
end user
Posts: 212 |
I am being told 225 dollars for part.....Is there a cheaper non-OEM part that works for this part? Part number E340006 INDICATOR LIGHTS AND SCROLL SWITCH?
end user
Posts: 21,870 Likes: 167
Posts: 21,870 Likes: 167 |
Check on e bay, you might drop lucky.
Posts: 35,784 Likes: 471
Posts: 35,784 Likes: 471 |
Is it in the alternative parts list I wonder that the boys have running ?
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
I do not know of a good alternative for the stock MMC item. It has to work with the Turn Signal Module which narrows the selection down a lot. If anyone has got some information on alternatives please let me know and I will add it to the list. The stock item is very delicate and often breaks, operate it gently.....
Posts: 1,670 |
The lever fatigues and you buy the whole switch assy.
I don’t know of an alternative- caterham may well use similar but then they’d be more expensive
