10 members (DCH, ajg141, RichardV6, SCX358G, Robbie, TheCustomer, Colin_Mackay, Tweed19er, JMcL, nick w), 327 guests, and 38 robots.
John V6 69
+8Rich 67
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,044
Captain Morgan, IRWIN
#708356 30/06/21 07:51 PM
Bunny Offline OP
While messing with the flasher relay, I noticed the black box located under said relay. the box appears to be an add-on and seems to be connected to the relay indicated (which also looks like an add-on).
I was wondering if it may have something to do with the engine cooling fan retrofit? I'm sure someone here will know!
Mine is a 2012 car by the way.
Andy
I had a look into the black box a number of years ago and it had 3 or 4 relays in it. No idea what they are for so I left it alone. It was on before I had the cooling fan fitted.
Still no idea what not does.
Online NoMood
Could it be there to control the flux capacitor? Most of the public seem to thiink a Morgan is out of the past anyway....
Dave
Online NoMood
Andy, I have been studying the chassis loom diagrams both pre and post 2014 in an attempt to discover purpose of extra relay. Both diagrams show five relays with the early diagram showing fifth as flasher relay and later one as cooling fan. I'm guessing the flasher relay was incorporated in TSM unit for later models as this has 18 pin connector (two pins unused) against 12 pin one on earlier versions.
This doesn't help with identifying extra relay though so looked closely at cable colours to it. A red/blue (RU) cable can be seen which is unique in providing power to rear fog lamp. Thoughts are that relay may be to inhibit rear fog when headlights not on therefore although not shown on diagrams. Pure speculation of course.
The black box you queried is described as dip/main beam unit although unsure of its need as you already have two standalone relays to handle dip/main and headlamp flash confused2
Hi,
I retro fitted the cooling fan to my 2013 and this looks like the fan relay
Fan Relay
SFG Offline
Pull it out and see what doesn’t happen?
SFG
2012 4/4 Sport
Hi Bunny/Andy
Isn't the black box the TSM/Lighting Control control unit - the one that Alastair is looking to improve/replace?
I think the relay is the one added that controls the cooling fan.
Regards
Andrew
Currently
2011 M3W
986 3.2S
Z4 M40i
Cectek Estoc
Midget 1275
1959 Frogeye Sprite
2022 Defender 90 HT
Bunny Offline OP
Originally Posted by ajsms999
Hi Bunny/Andy
Regards
Andrew
No this is a different box, the TSM is fitted below the ECU.
Andy
Online NoMood
Andy, as previously mentioned. The black box you were querying is shown here as (7), dip/main unit E340015 even down to the velcro attachment. Thoughts to its need are as interface between stalk control and the two headlamp relays. Since I believe the TSM unit is involved as well must make the headlamp controls the most complex on this planet confused2
Bunny Offline OP
Mystery solved. Many thanks Richard!
Andy
