4 members (Paulxj, Clipper, TrickieDickie, BobtheTrain), 224 guests, and 87 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
gavin Offline OP
I noticed yesterday that when I flash my high beam, with the lights off, it doesn’t flash. With the lights on it both flashes and also high beam works as it should.
The car is a 95 plus 8, can anyone suggest where I need to start looking for the fault?
1995 Plus 8
1984 4/4 4 Seater (prev)
On my 94 +8 I had a slightly different issue, my highbeams wouldn't work with the headlights on but would flash. I ended up having to take the stalk mechanism apart, clean the electrical contacts and bend them to make them a tighter fit that resolved the issue.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Like Bruce, I'd go for the stalk first.
gavin Offline OP
Thanks britmog, I’ll give that a go.
1995 Plus 8
i guess a quick squirt of contact cleaner as step 1 might help.If rarely used they can corrode over.
One thing to be aware of is that the standard steering column stalk switches don't like carrying the higher current that headlamps demand, and in the 80's and 90's MMC didn't see fit to install headlamp relays.
Fortunately it's an easy fix and once done will ensure your dipswitch will carry on working happily.
Here's a document explaining what to do
That's a good idea another project for a rainy day.
Bruce
2013 M3W (Olga)
That looks very much like the work of the late Lars Tim?
Andy G
1999 +8 , Indigo Blue.
It is indeed, bless him.
gavin Offline OP
Hamwich, thanks for that and definitely something I will look for, but sadly I know when to throw the towel in and as much as I’d love to do a job like that I think when it comes to snipping wires I know full well that wiring and electrics is way beyond me.
1995 Plus 8
