9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff),
298
82
Topics49,858
Posts837,463
Posts: 305 |
On start up I am getting a squeal that goes away as the engine warms up , I inspected the belt all looks well ,it has been sprayed with belt dressing . . I think it must be a idler problem ,the car is 6 years old with 15 K miles . I am wondering if I should just address this problem or while I am at it get the timing belt changed as well .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
You could help us by actually letting us know what year/model Morgan you have?
Arwyn
Posts: 1,415 |
Arwyn
It's a 2015 4/4 Sport as in his signature maybe....?
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Looking at the signature - 2015 4/4
Which means the drive belt is 6 years old. Mine lasted around 5 years. The screech is the belt slipping after start up. Fit a new bet and it will go away.
Replacement is a Gates 6PK1203. I got mine from BHM IIRC but you can find them online easily.
Replacement is easy - the tensioner pulley is spring loaded. A spanner will slacken the tension so you can remove the old belt and then fit the new one. Make sure you make a good mental note of the belt routing before removing the old one.
Posts: 2,092 Likes: 72
Posts: 2,092 Likes: 72 |
Just to add to the above, looks like you are not doing much mileage, the battery may be draining down; indeed a battery of that age may be within seeing distance of its demise! When you start, the alternator has to put out a large amperage, which in turn places more mechanical load on the belts and pulleys causing slip. As the battery recovers, the load diminishes and squealing stops. As a matter of interest, Regarding part numbers: 6PK1203...the 6 is the number of ribs and the 1203 is the circumferential length of the belt in mm.
Posts: 305 |
Thanks for the advice ,I've got a new belt ,I'll fit it and report back . Belt dressing should stop the belt slipping that's why I suspect an idler .
Posts: 305 |
New belt fitted , no more squeals . Always good advice on TM .
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
