0 members (), 424 guests, and 66 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
#709091 08/07/21 09:06 AM
jimmyw Offline OP
On start up I am getting a squeal that goes away as the engine warms up ,
I inspected the belt all looks well ,it has been sprayed with belt dressing . .
I think it must be a idler problem ,the car is 6 years old with 15 K miles .
I am wondering if I should just address this problem or while I am at it get the timing belt changed as well .
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
You could help us by actually letting us know what year/model Morgan you have?
Arwyn
Arwyn
It's a 2015 4/4 Sport as in his signature maybe....?
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Looking at the signature - 2015 4/4
Which means the drive belt is 6 years old. Mine lasted around 5 years. The screech is the belt slipping after start up. Fit a new bet and it will go away.
Replacement is a Gates 6PK1203. I got mine from BHM IIRC but you can find them online easily.
Replacement is easy - the tensioner pulley is spring loaded. A spanner will slacken the tension so you can remove the old belt and then fit the new one. Make sure you make a good mental note of the belt routing before removing the old one.
Costock, UK
Disco 5
Just to add to the above, looks like you are not doing much mileage, the battery may be draining down; indeed a battery of that age may be within seeing distance of its demise!
When you start, the alternator has to put out a large amperage, which in turn places more mechanical load on the belts and pulleys causing slip. As the battery recovers, the load diminishes and squealing stops.
As a matter of interest, Regarding part numbers: 6PK1203...the 6 is the number of ribs and the 1203 is the circumferential length of the belt in mm.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
jimmyw Offline OP
Thanks for the advice ,I've got a new belt ,I'll fit it and report back .
Belt dressing should stop the belt slipping that's why I suspect an idler .
Jimmy
2018 VW Tiguan
jimmyw Offline OP
New belt fitted , no more squeals .
Always good advice on TM .
Jimmy
2018 VW Tiguan
thumbs smile
Good news.
Costock, UK
Disco 5
