8 members (Davetherave, Chris Cosher, Ian Wegg, John Winn, mph, MDS61, Tony Quinn, Jon G4LJW),
228
Topics48,337
Posts812,912
Members9,203
Posts: 2,255 Likes: 2
Posts: 2,255 Likes: 2 |
Hello everyone.
I have a friend in England with a 2005 P4. He thought that he had a dead battery as the car had not moved for nine weeks as he was here. The new battery is fully charged, there is rapid clicking when the ignition key is operated but the engine will not crank over. I have sent him tests to do but thought that you all might have a quick solution. Thanks in advance for replies.
Posts: 6,056 Likes: 160
Posts: 6,056 Likes: 160 |
The rapid clicking will be the starter solenoid. It does sound like there's not enough juice in the battery to crank the engine over. Has he tried a jump start?
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
My next step would be a stuck starter motor?
Posts: 5,217 Likes: 121
Posts: 5,217 Likes: 121 |
Have the new battery connections and the leads been checked. If the battery is fully charged, it may be that disturbing the earth lead has introduced a high impedance.
Paul, I\ll get him to check that although I'm sure I mentioned it: TBM, yep tried a jump start. Could well be the starter motor, possibly an alternator problem but he could test for that.
He is quite near to Tim Ayres so if all else fails....
Posts: 5,041 Likes: 312
Posts: 5,041 Likes: 312 |
As above, if the battery is sound (able to maintain voltage even under starting load as opposed to just with a meter across it) .... then I'd check power and earth connections, especially as it's been sat.
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
There should be an earth strap from the engine to the chassis, undo the bolt at the chassis end as it might look ok but when you take off may need cleaning up.
With the jump start, suggest connect the leads in the engine bay rather than to the battery terminals
Tim Plus 4 2018
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
Definitely clean the earth strap
