5 members (mph, Luddite, lord-richfield, DickJ, John Winn), 268 guests, and 39 robots.
John V6 79
+8Rich 70
DaveW 68
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,932
Members9,203
toitoine
Page 1 of 6 1 2 3 4 5 6
#714080 13/08/21 02:59 PM
meabh Offline OP
Hello everyone.
I have a friend in England with a 2005 P4. He thought that he had a dead battery as the car had not moved for nine weeks as he was here. The new battery is fully charged, there is rapid clicking when the ignition key is operated but the engine will not crank over. I have sent him tests to do but thought that you all might have a quick solution.
Thanks in advance for replies.
meabh #714081 13/08/21 03:07 PM
TBM Offline
The rapid clicking will be the starter solenoid. It does sound like there's not enough juice in the battery to crank the engine over. Has he tried a jump start?
meabh #714082 13/08/21 03:10 PM
TBM Offline
My next step would be a stuck starter motor?
meabh #714084 13/08/21 03:13 PM
Have the new battery connections and the leads been checked. If the battery is fully charged, it may be that disturbing the earth lead has introduced a high impedance.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
meabh #714086 13/08/21 03:18 PM
meabh Offline OP
Paul, I\ll get him to check that although I'm sure I mentioned it: TBM, yep tried a jump start. Could well be the starter motor, possibly an alternator problem but he could test for that.
meabh #714087 13/08/21 03:19 PM
meabh Offline OP
He is quite near to Tim Ayres so if all else fails....
meabh #714088 13/08/21 03:20 PM
As above, if the battery is sound (able to maintain voltage even under starting load as opposed to just with a meter across it) .... then I'd check power and earth connections, especially as it's been sat.
meabh #714099 13/08/21 04:19 PM
meabh Offline OP
Image , will do, thanks
meabh #714116 13/08/21 05:50 PM
There should be an earth strap from the engine to the chassis, undo the bolt at the chassis end as it might look ok but when you take off may need cleaning up.
With the jump start, suggest connect the leads in the engine bay rather than to the battery terminals
Tim
Plus 4 2018
meabh #714123 13/08/21 06:35 PM
Definitely clean the earth strap
2025 MG ZS EV aka Trigger
