0 members (),
129
32
Old Book
Topics49,940
Posts838,603
Posts: 37,499 Likes: 996
Posts: 37,499 Likes: 996 |
I suspect that the braking effects have a great deal to do with the weight or lack of it with our Morgans. We tend to glide along the surface and going at the speed the driver was doing any braking prowess would not work in the distance he left himself to stop in. My thoughts too Bruce, the Plus 8 has a bigger footpint (could it be any smaller than the 4/4 Sport) and of course carries a lot more weight on the front wheels and you really have to stomp hard to lock a front is my experience. The Sport would lock up with minimal input with the Conti's, the Toyo's were a lot better but the tendency was still to lock up but they were better in the wet.
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
I made Django a feeding station as he has grown pretty quickly and is now 26kgs and about 50cm to the top of his head. I could not find a suitable unit online. he was ![[Linked Image]](https://www.tm-img.com/images/2021/05/01/Puppy.th.jpg) He is now: ![[Linked Image]](https://www.tm-img.com/images/2021/09/02/34d27e37-b41b-4e7a-bb98-b5e7ff2452a7.md.jpg) It is made from two sheets of perspex laminated together and cut to accept the bowls. The legs are made fro Panga Panga and shaped. I bought the wood from Surrey Hardwoods who supply all types of exotic woods ![[Linked Image]](https://www.tm-img.com/images/2021/09/02/IMG_3065.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/09/02/IMG_3063.jpg)
Kevin
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Very nice Kevin, that's one lucky pooch.
Steve L.
1996 Plus 8 N22 MOG
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
Posts: 12,284 Likes: 329
Posts: 12,284 Likes: 329 |
A proper bodge from me today. The right rear indicator on the Landy failed yesterday whilst 'er indoors was on her way back from the water park. Not the fuse or bulb, but the contacts in the bulb holder had corroded and failed.
No problem getting hold of Defender light units, they are only around £4 for a pattern OEM job (£41 for a LR original part, would you believe?) but delivery takes a few days and we need the Landy again on Monday. We don't have the Fiat any more (traded in) and there's no way you can get 2 paddleboards and associated gubbins on the Morgan (good use case for a CX-T, I reckon).
So, cut the light tails, remove the plug from the rear of the unit, drill an M8 hole though the base of the bulb holder, ripping out the old contacts. Solder one wire to the centre contact of the bulb, wrap the exposed length of another wire around the base of the bulb, a bit of heat shrink to keep them isolated, feed the wires through the hole and out through the base of the holder, and jam the bulb back in to the holder with a bit of tape to hold it firmly in place. A chocolate block connector to hook the new wires into the cut tails, and we're back in action.
The new holders will be arriving next week, but I'm tempted to see how long this particular bodge will last before I replace them properly.
Posts: 28,918 Likes: 354
Posts: 28,918 Likes: 354 |
 Sounds good to me Tim!
Posts: 1,082 Likes: 72
Posts: 1,082 Likes: 72 |
![[Linked Image]](https://www.tm-img.com/images/2021/09/18/EB8C9322-E102-4853-9011-2447149E6568.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/09/18/D8DBDAF9-4FFA-4DE7-860E-02151FCFE58F.jpg) This isn't another one of yours as well is it Tim?
David Aero S4
Ha, i love the paint job! Ours is very boring in comparison. We have got a bigger trailer though  ![[Linked Image]](https://tm-img.com/images/2021/03/01/IMG_0228.md.jpg)
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Probably years!
Probably years! Indeed. My worry is not the longevity of the bodge, but what if a proper engineer gets to see it? I'm not sure I could bear the embarrassment!
