7 members (Gallanach, sospan, yobtaf, Morganmike, Alan Patterson, sbarracl, JMcL), 67 guests, and 36 robots.
John V6 63
Silicon cf. Silicone
by JMcL - 24/09/26 10:21 AM
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
First Morgan as it is now
by Strathaven, September 15
Topics49,941
Posts838,617
Page 43 of 53 1 2 41 42 43 44 45 52 53
Originally Posted by britmog
I suspect that the braking effects have a great deal to do with the weight or lack of it with our Morgans. We tend to glide along the surface and going at the speed the driver was doing any braking prowess would not work in the distance he left himself to stop in.
My thoughts too Bruce, the Plus 8 has a bigger footpint (could it be any smaller than the 4/4 Sport) and of course carries a lot more weight on the front wheels and you really have to stomp hard to lock a front is my experience.
The Sport would lock up with minimal input with the Conti's, the Toyo's were a lot better but the tendency was still to lock up but they were better in the wet.
I made Django a feeding station as he has grown pretty quickly and is now 26kgs and about 50cm to the top of his head. I could not find a suitable unit online.
he was
He is now:
It is made from two sheets of perspex laminated together and cut to accept the bowls. The legs are made fro Panga Panga and shaped. I bought the wood from Surrey Hardwoods who supply all types of exotic woods
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Very nice Kevin, that's one lucky pooch.
Steve L.
1996 Plus 8
N22 MOG
John V6 Offline OP
+1. Very smart
A proper bodge from me today. The right rear indicator on the Landy failed yesterday whilst 'er indoors was on her way back from the water park. Not the fuse or bulb, but the contacts in the bulb holder had corroded and failed.
No problem getting hold of Defender light units, they are only around £4 for a pattern OEM job (£41 for a LR original part, would you believe?) but delivery takes a few days and we need the Landy again on Monday. We don't have the Fiat any more (traded in) and there's no way you can get 2 paddleboards and associated gubbins on the Morgan (good use case for a CX-T, I reckon).
So, cut the light tails, remove the plug from the rear of the unit, drill an M8 hole though the base of the bulb holder, ripping out the old contacts. Solder one wire to the centre contact of the bulb, wrap the exposed length of another wire around the base of the bulb, a bit of heat shrink to keep them isolated, feed the wires through the hole and out through the base of the holder, and jam the bulb back in to the holder with a bit of tape to hold it firmly in place. A chocolate block connector to hook the new wires into the cut tails, and we're back in action.
The new holders will be arriving next week, but I'm tempted to see how long this particular bodge will last before I replace them properly.
thumbs Sounds good to me Tim! grin2
This isn't another one of yours as well is it Tim?
David
Aero S4
Ha, i love the paint job! Ours is very boring in comparison. We have got a bigger trailer though smile
Formerly known as Aldermog
Probably years!
Probably years!
Indeed. My worry is not the longevity of the bodge, but what if a proper engineer gets to see it? I'm not sure I could bear the embarrassment! grin2
