1 members (DJC), 291 guests, and 35 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#719949 30/09/21 08:22 PM
Carl44 Offline OP
Hi this is the first time on this site.
I have a 2006 70th anniversary 4/4 1800 duratec could anyone tell me what oil is suitable for this engine
Thanks
Carl
Carl44 #719953 30/09/21 09:06 PM
According to the handbook:
5.8 litres incl filter (approx)
SAE5W30 semi synthetic
SAEW40 fully synthetic
SAE5W40 mineral oil
4/4 70th Anniversary Edition (1996)
Carl44 #719960 30/09/21 11:49 PM
Hi Carl 44,
Let me be the first to welcome you to the forum, I’m sure you will find it a great source of info together with a few laughs.
Over the years Ford slightly changed oil recommendations to suit engines, probably emissions and mpg figure related.
Following my own look at oils a long, long time ago I have always used Castrol Magnatec 5W30 fully synthetic. It meets Ford requirements and has always been a really good price at Costco, presently about £22 for 4 litres.
Assuming MMC didn’t change items during the production run then your sump is as mine, a propriety item. The sump plug will look like a shouldered bolt and is an M12 X 1.75 X 21mm with a hex head. Mine had/has a dowty/ bonded washer. Don’t overtighten! They can be reused many times but if in doubt replace cos they are only pennies. Interestingly, MMC have no record of ever using these!
Definitely 5.8 litres fill and if you slightly raise the front nearside it will help drain that extra dreg!
Hope this helps
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Carl44 #720013 01/10/21 01:42 PM
Welcome Carl
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Carl44 #721590 14/10/21 08:48 PM
Carl44 Offline OP
Hi AlanH , Salmo ,Kevcaster
Thanks for making me feel welcome on the site,I will be going out now to pick up magnates 5w30 fully synthetic and a filter thanks for your help.
Carl👍
