10 members (RichardV6, Image, Graham, G4FUJ, Sir Percival, HKNYMOG, Gordon D, Rovert, MartO, IcePack, Montegue),
159
48
Topics49,846
Posts837,375
Posts: 125 Likes: 3
Posts: 125 Likes: 3 |
Done about 400 miles in the car since I got it earlier this month and am learning some of the quirks of morgans, thanks to your help mainly!  Recently a squeal has begun to develop on down shifts then it started on throttle lift off as well. Its really quite loud and is seemingly getting worse. On down shifts it begins at the clutch bite point which makes me think it is clutch related. But it makes the noise on throttle lift as well which does not have a bite point. Which makes me wonder if something is about to fail? Has anyone else experienced this please? I would rather have my rattly steering wheel back over this!
Posts: 488 |
The first thing I would check is drive belt alignment, it can track from one side to the other of the rear pulley when going from power on to over run and can rub on the guide plates and cause squeaking. You will find plenty of threads on how to adjust if you do a search.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Agreed, almost certainly drive belt alignment rather than the clutch. Dust can also cause this if you have driven over a bit of dusty road recently? I am sure the rattly steering wheel could return as well as the squeal 😁. This car will never be one for cruising along silently.
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
My rhythmic squeak stopped when I had the original sprocket replaced with one of the poly covered ones.
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
I find that my Morgan gets quieter the longer I drive it. Although come to think of it, that could be my hearing is getting worse.
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 125 Likes: 3
Thanks guys, appreciate the guidance. Will investigate the belt alignment.
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
Belt tension also caused a groan-like low-pitched squeal for me.
Aka Joejoe
Posts: 63 |
I find that my Morgan gets quieter the longer I drive it. Although come to think of it, that could be my hearing is getting worse.  Amen Brother, right there with you!
2016 M3W
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
