10 members (John07, Hamwich, Dada, britmog, RJW, Rex_tulips, John Winn, Alan Patterson, david nathan, Graham, G4FUJ), 279 guests, and 36 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,393
Members9,215
Rbt Aero8, Salmon, stevends
#722720 26/10/21 09:15 PM
Done about 400 miles in the car since I got it earlier this month and am learning some of the quirks of morgans, thanks to your help mainly! cheers
Recently a squeal has begun to develop on down shifts then it started on throttle lift off as well. Its really quite loud and is seemingly getting worse. On down shifts it begins at the clutch bite point which makes me think it is clutch related. But it makes the noise on throttle lift as well which does not have a bite point. Which makes me wonder if something is about to fail? Has anyone else experienced this please?
I would rather have my rattly steering wheel back over this!
O
O
The first thing I would check is drive belt alignment, it can track from one side to the other of the rear pulley when going from power on to over run and can rub on the guide plates and cause squeaking. You will find plenty of threads on how to adjust if you do a search.
Agreed, almost certainly drive belt alignment rather than the clutch. Dust can also cause this if you have driven over a bit of dusty road recently? I am sure the rattly steering wheel could return as well as the squeal 😁. This car will never be one for cruising along silently.
My rhythmic squeak stopped when I had the original sprocket replaced with one of the poly covered ones.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
I find that my Morgan gets quieter the longer I drive it.
Although come to think of it, that could be my hearing is getting worse. smile
Craig - Texas, USA
2021 M3W
Thanks guys, appreciate the guidance. Will investigate the belt alignment.
Belt tension also caused a groan-like low-pitched squeal for me.
Aka Joejoe
Amen Brother, right there with you! cheers
2016 M3W
huh?
Rodger
2004 Plus 8 (wife's)
Ear plugs…
