7 members (CooperMan, verysideways, JohnHarris, Mike D, Luddite, Hamwich, Martin W), 428 guests, and 93 robots.
+8Rich 80
DaveW 52
Topics49,866
Posts837,600
Mine looks like this:
with a min. and max. line...
1973 2CV AK400 Ralley
1985 plus 4 four seater
1992 Peraves ecomobil
bicycles (pedersen to recumbent)
Rob,
What I was thinking was to put 3.83 litres of oil in engine, mark dipstick at that point as Low, add 1 litre & mark that level as high....
Jack
1985 4/4 T/C 4 seater Royal Ivory
1934 F Type
2018 Pembleton SuperSport (self built).
Originally Posted by RobC
Looks like I should source an Argenta Haynes Manual!
Thanks.
Rob,
The engine number on my 4/4 cross references to a Fiat Argenta, if yours does too (132D1.000) then I suggest a Fiat factory Argenta Owners Handbook as a source document, service settings given are different to those in my Morgan factory handbook (which appear to be for an earlier Fiat engine).
Jack
1934 F Type
RobC Offline OP
Thanks for those pics Mkiss and the details from others.
I've ordered the Haynes manual from eBay, arriving Saturday, though how much will look the same as our engine will be interesting to see. It started life with fuel injection but judging from the bills and info that came with the car it had the single twin-choke Weber swapped in years ago.
Great help from this forum, thanks again. cheers
1986 Plus 4, Fiat 2L TC stage II tuned 4-seater
Assistant Passenger/Map Reader/Mechanic
Rob,
Fortunately, the Haynes Fiat Argenta manual also covers the earlier 132 2 litre fitted with a single twin choke Weber.
If your car has the standard Fiat twin cam ADF carb fitted this is better illustrated in the less common Autobooks Fiat 132 manual.
Good luck
Jack
1934 F Type
