5 members (John07, IcePack, B3MOG, +8Rich, Arwyn Williams), 289 guests, and 41 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
1340fxd Offline OP
So, my 1997 +8 3.9 Hotwire can’t breathe! Well, it has that standard air filter canister with a trumpet. Fitting a K&N in that canister doesn’t look like the way forward as there is so little space for the engine to suck air.
Not wanting to butcher my original parts (just so I can put it all back together as original if I should want to) I have managed to get a used air filter canister off eBay (Land Rover part NTC4408). I have cut this down on the engine side which connects to the Air Mass Flow Meter, leaving the original mounting points and most of the airbox has gone, leaving only the lower part going out to the other two mounting points. To finish, I am having a 3 ½ tube welded on to lengthen the intake so a K&N RG-1001 clamp on filter will fit.
When it’s back from the welder, I should have something that fits to the original mountings and which will hold everything in place to allow the K&N to breathe freely. I’ll post some pictures when I get it back from the engineer.
Now here is where I need some help, please. How do I remove the standard air filter canister and fit the newly fabricated one? Obviously, it simply unclips from the Air Mass Flow Meter. After that, looking at the mounting points there are two rubbers sitting on pins (ditto the filter side. Do these just pull out or what is the procedure to remove the air filter box and also, are these rubbers replaceable?
1997 +8 BRG, BMW Z4, Harley FXD, Greeves Silverstone RDS, Kawasaki H2 & Z1000 - no electric cars!
The canister just pushes inboard, off the mounting pins. I just mounted a K&N straight where the canister connects, but did have a small tube to start with.
06 Saab 93
1340fxd Offline OP
I can see you need to slide the air filter canister inboard to free it from the horizontal pins on the outside BUT to do that it looks like you need to lift it up on the inboard to first clear the vertical pins? Problem appears to be the canister is a tight fit underneath the central bonnet support. What's the trick to overcome this please?
There should be enough clearance once you push it back off the pins, there was in my case. I wanted to have air flow from outside the engine bay so concocted this set up using an old canister and K&N cone filter, works a treat:
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
This is how i replaced initially
06 Saab 93
Hello Bruce, that looks good - can you let us have the K&N Part No: please ?
Many Thanks
Andy
My filter is an old one (15 years) the new filter reference numbers are:
RG-1001WT (Silver)
RG-1001 BL (Blue)
RG-1001RD (Red)
They come with 3 different adapters that allow it to fit to the air flow meter, in my adaptation the filter fits snugly into the open end of the canister.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Rex Offline
1340fxd
Did you finish this modification and installation? If so, could you post some photos, please?
Rex Greenslade
Charlevoix, MI, USA
1992 Plus 8
