5 members (Paul F, lez, stumog, BobtheTrain, Image), 353 guests, and 48 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 14 of 18 1 2 12 13 14 15 16 17 18
Originally Posted by RichardA
I was hoping to hear that! In that case this doesn’t seem to be a reason for anyone to hold off getting in there and buying as much enjoyment as these cars deliver.
Richard, another tip is that the header tank should not be filled above half (when cold) as the expansion when running hot was putting undue pressure on the system as the cap doesn't vent quite like old style rad caps
Apparently this was learnt late this year when running the Plus Four race cars
PiGo #727042 09/12/21 06:44 PM
Originally Posted by Robbie
According to the factory the issue was "a manufacturing issue with the manufacturer" apparently the radiators with "the new components" are now with the factory and one is "on the way "to my dealer! That was 2 weeks ago - even with the crazyness of Post-Brexit, I would have thought it shouldn't take this long to swim the Irish sea!!!!
That's what my dealer said.
The welding of the fans would be weakened by the heat given off by the welding of the tube.
+8Rich #727350 12/12/21 04:12 PM
JJR Offline
Originally Posted by +8Rich
+1 after two years it's a very sorry state of affairs.. at least with our trads there is a permanent fix with the Alloy upgrade.
I expect Sifab and Mulfab will get into this as an alternative solution shortly for the CX chassis series.
Lets hope the Ford engined new CX won't be similarly affected.
?? the new Ford engined CX?? Did I miss something?
John R Marchant
Plus Four JT10MOG "Florence"
JJR #727351 12/12/21 04:15 PM
Yes, the replacement three wheeler which has a Ford 3 pot engine and is based on the CX chassis wink
+8Rich #727435 13/12/21 10:29 AM
JJR Offline
Thanks Richard.
I knew the three wheeler is getting the three pot Ford motor, non-turbo apparently, but didn't know it was CX based. Presumably just the front end?
John R Marchant
JJR #727469 13/12/21 03:05 PM
Thanks Richard.
I can only see this as being a big car John using that chassis and my understanding is that from the excellent gearbox onwards it is a similar drivetrain to the M3W, happy to be corrected on that.
Had they have kept the Ford FWD I would seriously have considered one once the beta testing was out of the way.
PiGo #727473 13/12/21 03:26 PM
Big car?...
I am assuming that the new M3W will not share the exact same chassis as the plus 4 and plus 6, but will be much smaller. Bear in mind that the CX designation was applied to the new type of aluminium construction to recognise Morgan’s 110 years in business. I would guess any size of Morgan chassis designed on similar principles and made from bonded aluminium would fall under the generic umbrella of “CX”.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
PiGo #727475 13/12/21 03:34 PM
I'm looking forward to seeing one in the metal sans dazzle paint job, I guess it will break cover in the New Year around what would have been GMS time.
PiGo #727482 13/12/21 03:50 PM
The drive train is the same Richard. Built in problem from day 1.
PiGo #727501 13/12/21 04:54 PM
Thanks John, I thought it was,not good news really.
