6 members (Ian Wegg, britmog, Bishmog, James B W, Dada, Ulfulf), 289 guests, and 39 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,395
Members9,215
Rbt Aero8, Salmon, stevends
Page 5 of 7 1 2 3 4 5 6 7
I think to S1 update that Librands did was the Superchips Bluefin jobbie, may be worth a look at their website direct and tap in the search a similar Ford V6 of the correct era
CooperMan, from this and an earlier post in this thread I understand that you have had an S1 for a long time and also had it remapped (Superchips Bluefin?) Would you care to share your experience with the remapping? Is it worthwhile? Sheer power? Torque?
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Yes I had an S1 for around ten years and carried out many improvements for drivability and comfort, but didn't post much on TM back then
The Superchips Bluefin upgrade can be done by yourself through the OBD port as it's a handheld module that firstly copies & downloads your current map (so you can revert back) and then uploads the new one, very easy takes around 20 mins
From memory it may have perhaps removed a little flat spot at low throttle settings, but no significant difference in performance, acceleration or top end, I used to sometimes drive it (cough) properly on the second set of cams and it would bounce on the rev limiter just the same, as you know they can be surprisingly quick
Just my personal opinion, but the S1 is mapped very well for road use and I would not bother with the Bluefin again
Also worth noting that the Bluefin in a basic generic map and appears to be sold to cover multiple V6 Fords, all on the same module, but the ability to revert back to OE setup is useful
The S1 is a great set up. I agree I wouldn't map it.
2025 MG ZS EV aka Trigger
What I read about rev hang with these engines in other cars was tied to a certain batch of throttle bodies, I was preparing myself but with my 2010 I never experienced it.
Mark - No Longer driving
My (very) early 2009 S2 has experienced this twice during its life. Remedied by replacing firstly the Throttle Position Sensor, then later the Idle Control Valve, likely attributable to very low mileage in some years, and "getting stuck" (to use the non-technical expression).
I was fortunate enough to buy CooperMan’s S1 roadster which came with the Bluefin to connect to the OBD port, if anyone would like to try this. I am willing to lend it out for the price of the postage to wherever, on condition that it is a loan and is returned to me after use.
Colin.
RX450 easier ezchair.
2004 Roadster.CM51ERS.
Second set of cams? It didnt have variable valve timing....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
But a mass or torque as you went past 3,000 rpm.
That was a resonant pressure peak in the inlet manifold that caused that. The cams and exhausts I developed for the racers were designed to enhance that pressure peak
Simon @ Sifab.co.uk
