2 members (Ian Wegg, Richardllll), 234 guests, and 43 robots.
Adam12 69
+8Rich 68
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,389
Members9,215
Rbt Aero8, Salmon, stevends
I am told that the throttle body for the S&S Super E is the same config as the x-wedge. Has anyone tried to fit this stealth kit? The backing plate would work...are there mods that would have to be done to make it work?
https://www.sscycle.com/products/st...er-e-g-carburetor-or-52mm-throttle-body/
end user
The car cleaner you provided a link to looks to mount directly to the (Harley) cylinder heads, while the x-wedge version has link brackets for mounting. Perhaps you could contrive a suitable mounting arrangement. It does appear the throttle body mounting is the same. You do need solid mounting to the heads, as simply mounting by the three screws on the throttle body can cause put undue strain on the intake manifold gaskets creating leaks there.
Late 2012 M3W
Steve, thanks. So you need part 9 in this image, no?
end user
Here are the S&S numbers for these individual parts. Part 9 is 170-0202
end user
end user
Buy the universal and then order this separately?
https://www.sscycle.com/search/?keyword=106-1724
end user
The universal looks like the better choice. The brackets are just flat steel, with spacers or washers required for the rear (right) cylinder head, so easy to fabricate. You will still need the cover of your choice.
If your goal is better airflow, you can mod the factory air cleaner by enlarging the lower cutout and reducing the diameter of the backplate to match the OD of the air filter element. The factory filter element is actually larger than the so called high performance one, it just needs a little help in exposing the element.
Late 2012 M3W
+1 , the Stinger is the only thing missing on the OEM filter. If you could get a Stinger into a G56 cover you would have a pretty good filter.
Is there a simple replacement for the stock filter cover? Something in chrome would look a bit better than the flat-black stock item.
M3W 2017 Sport blue.
see https://mogparts.net/shop/three-wheeler/accessories ?
See also
http://www.talkmorgan.com/ubbthreads.php/topics/134453/all/replacement-air-cleaner-cover
Etc etc
