12 members (Mats, Julian BB, Mr K, JohnHarris, Biggle, JMcL, Sir Percival, mph, Bitsobrits, John Winn, Burgundymog, BobtheTrain),
407
Topics49,859
Posts837,504
Posts: 141 Likes: 3
Posts: 141 Likes: 3 |
Thought Morgan were about to release the new replacement, anyone seen or heard anything? Landy
Posts: 82 Likes: 1
Posts: 82 Likes: 1 |
We at least need a picture of the CX chassis and suspension to keep us engaged. I keep going back and forth between the Liberty ACE 2.0, the 3 Wheeler and the 3/3. Right now the 3 Wheeler is winning.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
I wonder how many threads there will be about the new 3 wheeler launch? https://www.morgan-motor.com/future-three-wheeled-morgan/The full info will come when they are ready!
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
We at least need a picture of the CX chassis and suspension to keep us engaged. I keep going back and forth between the Liberty ACE 2.0, the 3 Wheeler and the 3/3. Right now the 3 Wheeler is winning. I would bet the Ace will be more reliable and handle better.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
gold wing engines go forever (I still am the OEM owner of a 78) and best of all. Timing belts are available
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
gold wing engines go forever (I still am the OEM owner of a 78) and best of all. Timing belts are available I broke one  1979 GL1000 It had done 120,000+ but it stripped the teeth off the rear crank pulley. No idea how or why! Popped a couple of skirts off the carb pistons too. Stuffed another engine in, and got Jon and Wingovations to rebuild an ebay set of carbs and all sorted now. if you want a plastic car with a second hand (but extremely reliable) engine, then the Ace is the one to go for.
gold wing engines go forever (I still am the OEM owner of a 78) and best of all. Timing belts are available I broke one  1979 GL1000 It had done 120,000+ but it stripped the teeth off the rear crank pulley. No idea how or why! Popped a couple of skirts off the carb pistons too. Stuffed another engine in, and got Jon and Wingovations to rebuild an ebay set of carbs and all sorted now. if you want a plastic car with a second hand (but extremely reliable) engine, then the Ace is the one to go for. I misspoke.... USUALLY they go forever. I know Jon through nakedgoldwings. Currently I have a 76 Ltd which I was restoring. cannot get it to stay in gear. I can pop another engine in, but it will not be a Ltd engine (the Ltds were slightly different than the production 76's
gold wing engines go forever (I still am the OEM owner of a 78) and best of all. Timing belts are available I broke one  1979 GL1000 It had done 120,000+ but it stripped the teeth off the rear crank pulley. No idea how or why! Popped a couple of skirts off the carb pistons too. Stuffed another engine in, and got Jon and Wingovations to rebuild an ebay set of carbs and all sorted now. if you want a plastic car with a second hand (but extremely reliable) engine, then the Ace is the one to go for. I misspoke.... USUALLY they go forever. I know Jon through nakedgoldwings. Currently I have a 76 Ltd which I was restoring. cannot get it to stay in gear. I can pop another engine in, but it will not be a Ltd engine (the Ltds were slightly different than the production 76's Yes a dear friend had an LTD (called Yosemite Sam) in the Burgundy/Gold colour scheme. Jon is a great bloke - helped me out a lot. Trouble with the GL engines is when they do go wrong, they are a bugger to fix due to the set up of the casings.
yes, I asked another NGW guy who rebuilds bikes and does race bikes (i.e. highly skilled) and he said he had never broken the case on a GL1000... and guess you have to do if I need to replace a shift fork
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Not heard anything Landy but apparently the Geneva show is on again this year, Morgan traditionally unveil their new models here. I've no idea whether or not they will have a stand this year but I look forward with excitement to seeing the new M3W.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
