Morgan Aero 8
6 members (Craig Jezz, GrumpyPa, CooperMan, sprinty, Graham, G4FUJ, Morganmike), 294 guests, and 141 robots.
+8Rich 75
Topics49,869
Posts837,658
Moggo
#731295 26/01/22 09:24 PM
Has anyone experienced the Inertia Switch Warning Light suddenly for no reason illuminating but not causing a problem but will not extinguish until eventually timing out after removing the ignition key.Is this another quirky happening with the Aero
Smile, it confuses them
Which one is the Inertia Switch Warning Light ?
If I understand it correctly the inertia switch cuts the fuel pump in the event of a collision or roll over. If your engine was running normally during this anomaly, then likely to be just another Aero electrical gremlin.
I've had the similar with the handbrake and seatbelt warning lights too.
David
Aero S4
Sir S1'a'lot
Sir S1'a'lot
My inertia light is on quite often. Mind if it’s own
Series 1 though
2002 Aero 8 S1
2023 Plus 4 (woman’s)
PJC Offline
That's bound to be the integration of BMW CanBus in to Morgan wiring rofl
Cheers, Paul
its the exclamation mark ! warning light that comes on the dashboard
Thanks for your replies must be a gremlin. I tried pressing the inertia switch to perhaps reset things but what happens is that the car is totally isolated with electric power which is what would happen in a collision and you have to physically reset the mechanical switch to restore power, but the light is still on unfortunately.
le Asbo du Bling
le Asbo du Bling
Simon have you tried the reset button. This should clear the fault that's turning on the light?
Slowly going green
PJC Offline
If you have one of those OBD port diagnostic tools you may be able to clear the fault code from the ECU that way and the light would then go out.
Cheers, Paul
Have you tried tripping the circuit breaker on the front of electrics box. I know some owners use this to save the horrendous battery drain when car laid up for more than a few days.
Apologies if that is what you meant by mechanical switch.
